Isolate Elements temporary
Hi guys, i am trying to use this option IsolateElementsTemporary in Revit API. I already filtered theses elements and now i have a list with them but now how can i isolate them temporary?
Welcome, …
Please, do introduce yourself, and give us some context and code.
@brunodias ,
your are looking for that ?
uidoc     = __revit__.ActiveUIDocument
selection = uidoc.Selection #type: Selection
isoView = doc.ActiveView
def uwlist(input):
    result = input if isinstance(input, list) else [input]
    return result
# 🛒 PickElemnetsbyRectangle
elements = selection.PickElementsByRectangle('Elements')
idlist = List[ElementId]()
for e in elements:
	idlist.Add(e.Id)
# 🔓 Do some action in a Transaction
t = Transaction(doc,"isolate")
if len(elements) > 0:
	isoView.IsolateElementsTemporary(idlist)
# 🔒 done
i used a rectangle to isolate my elements.
Sorry, Jean. I should introduce myself before.
Hi everyone, I’m still learning how to use pyrevit and the revit API. I already know the basics enough about Python to start creating my own add-ins.
The context is that I work with piping in Revit and now I have many pipes, connections and accessories with the shared parameter LINE and P&ID filled in so I need to filter these elements more easily. this is the reason I asked about IsolateElementsTemporary.
Andreas, thank you!
it worked but as i am a rookie in Revit API i did not understand very well.
to complete the script i just needed to solve it > TypeError: expected ICollection[ElementId], got ElementId
i did as you showed but actually i would like to understand the different between Collection[ElementId] and ElementId. Could you help with it?
@brunodias ,
i know how hard it is to learn from scretch coding… :wink:
in my snippets there are not the moduls included… you have to import them as well.
here the code in total!
__title__ = "IsolateTemporary"
__doc__ = """Date    = 29.12.2023
Description:
isolate Elements by selection
Author: """
# IMPORTS
from Autodesk.Revit.UI.Selection import ObjectType, PickBoxStyle, Selection
# pyrevit
from pyrevit import forms, revit, script, DB
# .NET Imports
clr.AddReference("System")
for e in elements:
	idlist.Add(e.Id)
# 🔓 🔒  Do some action in a Transaction
with revit.Transaction("isolate"):
