Invalid number of references in NewDimension command
I want to create a code where you choose two points on a Revit model and create a new dimension on every structural element that intersects with the initial points. I have a working code where you can choose the two points (That create an outline) and the program filters the desired structural elements, finds the intersection points, arranges them from smallest to largest and when trying to create the new dimensions, an error always comes up that states that there is an Invalid number of references when my ReferenceArray has 2 references. I have tried with references on the line (GetEndPointReference) and currently I store the reference of the faces that intersected the original points to use them. My code is the following:
clr.AddReference('RevitAPI')
import RevitServices
import Autodesk.Revit.UI.Selection
docui = __revit__.ActiveUIDocument
tolerancia = 10
    punto1 = docui.Selection.PickPoint("Selecciona la esquina inferior derecha")
    punto2 = docui.Selection.PickPoint("Selecciona la esquina superior izquierda")
    print("Error al seleccionar puntos:", e)
    punto1 = None
    punto2 = None
if punto1 and punto2:
    direccion = "X" if abs(punto1.X - punto2.X) > abs(punto1.Y - punto2.Y) else "Y"
    if punto1.X == punto2.X:
        punto2 = DB.XYZ(punto2.X - 0.1, punto2.Y, punto2.Z)
    if punto1.Y == punto2.Y:
        punto2 = DB.XYZ(punto2.X, punto2.Y - 0.1, punto2.Z)
    elements_list = []
    outline = DB.Outline(punto1, punto2)
    X = 0
    Y = 0
    Zmax = None
    Zmin = None
    if not outline.IsEmpty:
        elementos_intersect = DB.FilteredElementCollector(doc) \
                                .OfCategory(DB.BuiltInCategory.OST_StructuralFraming) \
                                .WhereElementIsNotElementType() \
                                .WherePasses(DB.BoundingBoxIntersectsFilter(outline)) \
                                .ToElements()
        print(len(elementos_intersect))
        for element in elementos_intersect:
            geometria = element.Geometry[DB.Options()]
            if geometria:
                boundbox = geometria.GetBoundingBox()
                if boundbox:
                    if direccion == "X":
                        if abs(boundbox.Max.Y - boundbox.Min.Y) > abs(boundbox.Max.X - boundbox.Min.X):
                            elements_list.append(element)
                            Zmax = min(Zmax, boundbox.Max.Z) if Zmax is not None else boundbox.Max.Z
                            Zmin = max(Zmin, boundbox.Min.Z) if Zmin is not None else boundbox.Min.Z
                            print(element.Name)
                            X += 1
                        if abs(boundbox.Max.X - boundbox.Min.X) > abs(boundbox.Max.Y - boundbox.Min.Y):
                            print(element.Name)
                            Y += 1
        print("No se pudo encontrar elementos")
    altura = (Zmax + Zmin) * 0.5 if Zmax is not None and Zmin is not None else punto1.Z - 0.5
    print(altura)
    manager = DB.Transaction(doc, "Crear Cotas")
    manager.Start()
        punto1alt = DB.XYZ(punto1.X, punto2.Y, altura)
        punto2alt = DB.XYZ(punto2.X, punto2.Y, altura)
        punto1alt = DB.XYZ(punto2.X, punto1.Y, altura)
    linea = DB.Line.CreateBound(punto1alt, punto2alt)
    manager.Commit()
    print(X, Y)
    print(Zmax, Zmin)
    print(punto1, punto2)
    print(punto1alt, punto2alt)
    print(elements_list, len(elements_list))
    intersection_points = []
    referencias = {}
    for elemento in elements_list:
        geometrialen = 0
        geo = elemento.Geometry[DB.Options()]
        intersectResultArray = clr.Reference[DB.IntersectionResultArray]()
        for geomObj in geo:
            if isinstance(geomObj, DB.Solid):
                for face in geomObj.Faces:
                    min_distance = float('inf')
                    result = face.Intersect(linea, intersectResultArray)
                    if result != DB.SetComparisonResult.Disjoint and intersectResultArray.Size > 0:
                        for i in range(intersectResultArray.Size):
                            point = intersectResultArray.get_Item(i).XYZPoint
                            intersection_points.append(point)
                            for edge_loop in face.EdgeLoops:
                                for edge in edge_loop:
                                    curve = edge.AsCurve()
                                    distance = curve.Distance(point)
                                    if distance < min_distance:
                                        min_distance = distance
                                        closest_ref = curve.Reference
                                referencias[point.X] = closest_ref
                                referencias[point.Y] = closest_ref
    print(len(intersection_points))
    for l in range(len(intersection_points)):
        print(intersection_points[l])
    def sort_points(points):
        return sorted(points, key=lambda p: (p.X, p.Y, p.Z))
    def create_aligned_dimension(doc, line, ref1, ref2):
        t = DB.Transaction(doc, "Create Aligned Dimension")
        array = DB.ReferenceArray()
        array.Append(ref1)
        array.Append(ref2)
            dim = doc.Create.NewDimension(doc.ActiveView, line, array)
            return dim
            t.RollBack()
            print(e)
            return None
    def create_model_curve(doc, line, sketch_plane):
        t = DB.Transaction(doc, "Create Model Curve")
            model_curve = doc.Create.NewModelCurve(line, sketch_plane)
            return model_curve
            t.RollBack()
            print(e)
            return None
    sorted_points = sort_points(intersection_points)
    trans = DB.Transaction(doc, "Create SketchModel")
    trans.Start()
    plane = DB.Plane.CreateByNormalAndOrigin(DB.XYZ.BasisZ, sorted_points[0])
    sketch_plane = DB.SketchPlane.Create(doc, plane)
    trans.Commit()
    for i in range(len(sorted_points) - 1):
            ref1 = referencias[sorted_points[i].X]
            ref2 = referencias[sorted_points[i + 1].X]
            ref1 = referencias[sorted_points[i].Y]
            ref2 = referencias[sorted_points[i + 1].Y]
        line = DB.Line.CreateBound(sorted_points[i], sorted_points[i + 1])
        modelcurve = create_model_curve(doc, line, sketch_plane)
        dimension = create_aligned_dimension(doc, line, ref1, ref2)
        print(line.Id)
        print(dimension)
    print("No se encontraron los puntos")
Sorry for the Spanglish in naming of the variables and content of the promts.
you should check if this actually give you a reference object(try print(type(ref1)). I suspect because you only give it a .X which is a float it cant create a reference with a float so it thows that error
