I have installed pyRevit and when I launch Revit, a long list of errors appear.
What can be the possible solution to this?
Hi @MSalmanJavaid
You might have tried to launch multiple revit sessions at once. Each one trying to access the same pyrevit config file at the same time.
I just opened Revit once from the Taskbar and Desktop. Not opening the project directly. How can multiple sessions can be launched in that case?
@MSalmanJavaid my answer was an hypothesys. This is a case I encountered myself many times while launching multiple revit versions at once.
second hypothesis, you might wan’t to restart your computer.
check if you have a config file @ c:\programdata\pyrevit\pyRevit_config.ini
if not create one manually and launch revit again to see if that works
@MSalmanJavaid
@MSalmanJavaid See the solution here Error Loading pyRevit - PyRevitLoader · Issue #1461 · eirannejad/pyRevit · GitHub
After the install yesterday I was getting the INI file error and couldn’t load. I noticed that the pyRevit_config.ini file did not exist in the AppData\Roaming\pyRevit\ folder where the install page notes indicate that it should be.
