Inquiry about Chinese (Simplified) Language Support
Hello pyRevit Community,
First of all, thank you for this incredible plugin and the continuous efforts from the development team. It’s a fantastic tool that greatly enhances our workflow in Revit.
I would like to kindly ask if there are any plans to add a Chinese (Simplified) language interface for the pyRevit extension? As a user who is more comfortable with Chinese, having a localized interface would make the tool even more accessible and easier to use for me and potentially many other Chinese-speaking users.
If it’s not currently on the roadmap, could you please share if this is a feature that might be considered for future releases? Any information regarding localization efforts would be greatly appreciated.
Thank you for your time and for building such a wonderful community.
Hello again,
I’d like to offer my assistance to help move this forward. As a native Chinese speaker, I am willing to contribute by translating the user interface.
To get started, could the development team please provide a spreadsheet containing the English text that needs to be translated?
I’m not entirely familiar with the technical process of integrating translations into the plugin—whether it involves simple text replacement or a more complex localization framework. However, even if my contribution is limited to preparing the translated content, I believe it could be a significant help for future implementation.
Please let me know if this approach is feasible.
Thank you again for your consideration.
Do you have a name you go by for non Chinese speaking people around here.
The process is actually pretty straight forward. At a high level:
  1. Fork the repo
  2. Create a branch from develop branch
  3. Edit all the bundle.yaml files you can find on the repo and add under title: and tooltip: the chines_s locale like so:
title:
  ru: Очистить кэш BIM360 Collab
  fr_fr: Supprimer le cache BIM360
  en_us: Wipe BIM360 Collab Cache
  de_de: Lösche BIM360 Collab Speicher
  chinese_s: your translation here
tooltip:
  ru: Очищает выбранный кэш совместной работы BIM360.
  fr_fr: Efface le Collaboration Cache de BIM360
  en_us: Erase selected BIM360 collaboration cache
  de_de: Hiermit wird der BIM360 Collaboration Speicher gelöscht
context: zero-doc
Don’t edit anything else in each file, proofread, …
  1. Make commits after these changes, make it by batches of 10 files so that it is easier to review
  2. Make a PR from your branch against the develop branch on the pyrevit repo (you can actually make a draft pr and keep on working and commiting against your branch and once down, make it an actual of ready for review)
There are a few specific UI that can be translated differently, but I can walk you through once you are done with bundle.yaml which is already a lot.
There are also some UI s that are not designed for translation, but let’s keep that for another day
Hi Jean-Marc,
First of all, I’m sorry, I tried to find where to change the “Username” you mentioned but couldn’t find it.
Thank you so much for the detailed instructions and for being so supportive.
To be honest, the process you described is a bit beyond my current skills. I have no experience with programming, GitHub, or working with YAML files. I’m afraid I might accidentally break something if I try to modify the code repository directly.
My strength and what I can confidently contribute is the translation itself.
Would it be possible to provide me with a simpler way to get the text that needs translation? For example, could you or the team generate a simple list or a spreadsheet that contains all the title and tooltip English texts from the bundle.yaml files?
I can then take that list, fill in all the accurate Chinese translations, and send the completed spreadsheet back to you. This way, someone from the team (who is familiar with the code) can easily integrate the translations without any risk of me making technical errors.
I am still very enthusiastic about helping to bring the Chinese interface to pyRevit. I hope we can find a way that leverages my language skills.
Thank you for your understanding.
weice
It should be possible to have a script walk through all the folders, analyze the bundle.yaml and summarize their title-en_us and tooltip-en_us in a single file for editing.
A second script could do the re-import then. I’ll try if i can set sth up.
@Weice-pyRevit you can find a .csv here. Fill the last key with content.
Got it, thanks! This file is perfect.
I’ll start working on the translations now and let you know once it’s done.
Cheers
