Hi, thank you for your help! I finaly ended the script. There are few things to clean and add(like support other units apart from milimeters) but the script works.
from rpw import revit,db
from rpw.ui.forms import TextInput
from pyrevit import DB, forms
uidoc = revit.uidoc
## Class and def
def __init__(self, nom_categorie):
self.nom_categorie = nom_categorie
def AllowElement(self, e):
if e.Category.Name in self.nom_categorie:
# if self.nom_categorie.Contains(e.Category.Name):
#if e.Category.Name == self.nom_categorie:
return True
return False
return true
def Pargetstr(element, name):
return (element.GetParameters(name))[0].AsValueString()
## Picking elements
with forms.WarningBar(title="Pick elements in model[pipes/pipe fittings"):
collector = uidoc.Selection.PickObjects(ObjectType.Element,CustomISelectionFilter("Pipes Pipe Fittings"))
filter1=ElementCategoryFilter(BuiltInCategory.OST_PipeInsulations)
ins_list=FilteredElementCollector(doc).OfClass(ElementType).WherePasses(filter1).ToElements()
ins_list_pins=[Element.Name.GetValue(i) for i in ins_list]
rops = forms.CommandSwitchWindow.show(ins_list_pins, message='Select Option',
recognize_access_key=False)
print(rops)
choosen_ins=ins_list[ins_list_pins.index(rops)]
print(choosen_ins)
## Get types of elements to ask for insulation thickness
elements=[]
elements_type=[]
dict={}
for i in collector:
el=doc.GetElement(i.ElementId)
elements.append(el)
elements_type.append(el.Name)
element_parameters=[]
for p in el.Parameters:
element_parameters.append(p.Definition.Name)
print("=======")
print(el.Category)
print(el.Category.Name)
print(el.Parameters)
if el.Category.Name=="Pipes":
dict.update({Pargetstr(el, "Family and Type") +" "
+ str(el.Diameter*304.8):0})
elif "Nominal Diameter 1" in element_parameters:
+ Pargetstr(el, "Nominal Diameter 1") +" "
+ Pargetstr(el, "Nominal Diameter 2"):0})
+ Pargetstr(el, "Nominal Diameter"):0})
del element_parameters[:]
print(element_parameters)
print(elements)
print(elements_type)
print(dict)
## Ask for insulation thickness
for key in dict:
t=forms.ask_for_string(prompt='Select Insulation Thickness for {}'.format(key), title="Insulation")
dict.update({key:t})
print(dict)
transaction = Transaction(doc, 'Transaction')
transaction.Start()
## Set insulation to pipes
for el in elements:
t=float(dict[Pargetstr(el, "Family and Type") +" "
+ str(el.Diameter*304.8)])/304.8
Plumbing.PipeInsulation.Create(doc,el.Id,choosen_ins.Id,t)
print("=====")
print(Pargetstr(el, "Family and Type") +" "
+ str(el.Diameter*304.8)+ " Id: " + str(el.Id))
print("Insulation thicknes: {}").format(t*304.8)
+ Pargetstr(el, "Nominal Diameter 2")])/304.8
print("=====")
+ Pargetstr(el, "Nominal Diameter 2") + " Id: " + str(el.Id))
+ Pargetstr(el, "Nominal Diameter")])/304.8
print("=====")
+ Pargetstr(el, "Nominal Diameter") + " Id: " + str(el.Id))
print(e)
print("Error Element Id {}".format(el.Id))
transaction.Commit()
future reader! Next iterations you could get from: GitHub - PawelKinczyk/PYLAB: Python for Revit by using PyRevit extension
