Hi, I started to make some forms.alert in startup.py file in my pyrevit extension.
I could’nt find if there is a way to include an image (static of gif) inside a simple form (like a logo for example)
Is it possible in any way ?
Thank you
Thank you
pretty sure it is doable with the proper xaml template outside of this pre-built function.
Not answering your question…
But one note, using a forms.alert uppon startup forbid any other process to go past it if you don’t auto exit it or the user does not click ok or exit.
I did just that and also did that with a hook at file_opening time. It was a bad idea as some of my colleagues had automation going one and did not have any way to dismiss the window.
What I did instead, was to use a regular output window (there you can embed anything as it accepts html)
Noted, thank for this feedback, I will look around the output window for inserting image but now I have to learn how to control its appearance (and learn a little bit of html maybe ?)
Do you know if pyrevit.forms.toaster locks revit process also ? it seems not…
pyrevit.forms.toaster.send_toast(message, title=None, appid=None, icon=None, click=None, actions=None)
I doubt it
yeah, it depends what you are trying to achieve, but sky is the limit with html…
