Jean-Marc
(Jean-Marc Couffin)
September 22, 2022, 3:15pm
1
opened 09:34PM - 06 Jun 21 UTC
closed 04:38PM - 27 Feb 23 UTC
Prioritize
Benign Bug
Bundles
**Describe the bug**
Strange behavior of tooltip videos not loading in pyRevit … or other extensions buttons on the Ribbon.
After launching Revit (tested in 2019 and 2020) none of the buttons with a tooltip.mp4 file show a video in the tooltip.
After using the *Reload* command in pyRevit, the tooltip starts showing a **Video is loading...** text at the bottom of the tooltip, but the text then disappears and no video is shown.
To make sure it wasn't a codec issue, I tried using one of the OOTB Revit mp4 videos as a tooltip.mp4 video, but the behavior remained the same.
**To Reproduce**
Steps to reproduce the behavior:
1. Hover on a button
2. Wait for tooltip to show
3. See no video
**Desktop (please complete the following information):**
- OS: Win10
- pyRevit Version 4.8.7
- pyRevit Environment:
develop | Branch: "develop" | Version: "4.8.7:7f39f56" | Path: "C:\Users\david\OneDrive - Odeh Engineers\Repos\pyRevit"
==> Attachments
develop | Product: "2021.1.1" | Engine: DEFAULT (2711) | Path: "C:\Users\david\OneDrive - Odeh Engineers\Repos\pyRevit"
develop | Product: "2020.2.3" | Engine: DEFAULT (2711) | Path: "C:\Users\david\OneDrive - Odeh Engineers\Repos\pyRevit"
develop | Product: "2019.2.2 Hotfix" | Engine: DEFAULT (2711) | Path: "C:\Users\david\OneDrive - Odeh Engineers\Repos\pyRevit"
develop | Product: "2018.3.2" | Engine: DEFAULT (2711) | Path: "C:\Users\david\OneDrive - Odeh Engineers\Repos\pyRevit"
==> Installed Extensions
pyOdehTool | Type: UIExtension | Repo: "" | Installed: "C:\Users\david\OneDrive - Odeh Engineers\pyRevit\Custom Extensions\pyOdehTool.extension"
pyOdehToolWIP | Type: Unknown | Repo: "" | Installed: "C:\Users\david\OneDrive - Odeh Engineers\pyRevit\pyOdehToolWIP.extension"
templateBuddy | Type: Unknown | Repo: "" | Installed: "C:\Users\david\OneDrive - Odeh Engineers\pyRevit\templateBuddy.extension"
C:\Users\david\AppData\Roaming\pyRevit\Extensions
==> Extension Search Paths
==> Installed Revits
2021.1.1 | Version: 21.1.10.26 | Build: 20200909_1515(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2021\"
2020.2.3 | Version: 20.2.30.42 | Build: 20200826_1250(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2020\"
2019.2.2 Hotfix | Version: 19.2.20.24 | Build: 20190808_0900(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2019\"
2018.3.2 | Version: 18.3.2.7 | Build: 20181011_1500(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2018\"
==> Running Revit Instances
PID: 19236 | 2020.2.3 | Version: 20.2.30.42 | Build: 20200826_1250(x64) | Language: 0 | Path: "C:\Program Files\Autodesk\Revit 2020"
PID: 27484 | 2019.2.2 Hotfix | Version: 19.2.20.24 | Build: 20190808_0900(x64) | Language: 0 | Path: "C:\Program Files\Autodesk\Revit 2019"
==> User Environment
Microsoft Windows 10 [Version 10.0.19042]
Executing User: LEMONYSNICKET\david
Active User:
Admin Access: No
%APPDATA%: "C:\Users\david\AppData\Roaming"
Installed .Net Target Packs: v3.5 v4.0 v4.5 v4.5.1 v4.5.2 v4.6 v4.6.1 v4.7 v4.7.1 v4.7.2 v4.8
Installed .Net-Core Target Packs: v2.1.600 v2.1.602 v3.1.409 v5.0.104 v5.0.201 v5.0.203
pyRevit CLI 4.8.7.0
if someone is good at it and kind enough to look at it and if not fixing it point in the right direction, that woul be greatly appreciated
Related How Can I Add video to Tooltip
This seems to be working for me.
In Coreutils>ribbon.py
from Autodesk.Windows import RibbonToolTip
def set_tooltip_video(self, tooltip_video):
adwindows_obj = self.get_adwindows_object()
if isinstance(self.get_rvtapi_object().ToolTip, str):
exToolTip = self.get_rvtapi_object().ToolTip
exToolTip = None
adwindows_obj.ToolTip = RibbonToolTip()
if adwindows_obj and adwindows_obj.ToolTip:
adwindows_obj.ToolTip.Title = self.ui_title
adwindows_obj.ToolTip.Content = exToolTip
_StackPanel = System.Windows.Controls.StackPanel()
_video = System.Windows.Controls.MediaElement()
_video.Source = Uri(tooltip_video)
_StackPanel.Children.Add(_video)
adwindows_obj.ToolTip.ExpandedContent = _StackPanel
adwindows_obj.ResolveToolTip()
self.tooltip_video = tooltip_video
except Exception as ttvideo_err:
raise PyRevitUIError('Error setting tooltip video {} | {} '
.format(tooltip_video, ttvideo_err))
AliJALIL
(Ali)
February 21, 2023, 10:50am
3
martin.servold:
Should I Add this def to a py file ? or should i create it ? I can’t find the “Coreutils>ribbon.py” , in which folder may i find it ? Thank you Martin.
This would be a change to the pyrevit master branch. If you wanted to try to change it on your end you can find this file here:
{Pyrevit core install location}\pyrevitlib\pyrevit\coreutils\ribbon.py
The function above should already exist in that file, I’ve just made a few changes to it.
AliJALIL
(Ali)
February 21, 2023, 3:59pm
5
Worked perfectly ! Thank you Martin
Jean-Marc
(Jean-Marc Couffin)
February 27, 2023, 4:43pm
6
