How to extract Revit ID from schedule xls?
Hello PyReviter,
i want to extract, better to say, trigger transactions by RevitID.
Background is i got a filled excelsheet from a client. I have the RevitID as a reference. I have to fill based on that 30 parameters (columns)
In dynamo i already solved it. I have difficulties to get my data sorted, my code so far…
import xlrd
import os, sys, datetime
# pyRevit
from pyrevit import forms, revit, script
# Excel
clr.AddReference("Microsoft.Office.Interop.Excel")
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
# .NET Imports
clr.AddReference('System')
from System import Array
# List_example = List[ElementId]()
clr.AddReference('System.Drawing')
import System.Drawing
from System.Drawing import *
import time
uidoc = __revit__.ActiveUIDocument          #type: UIDocument
app   = __revit__.Application               # Application class
selection = uidoc.Selection # type: Selection
active_view  = doc.ActiveView
active_level = active_view.GenLevel
rvt_year     = int(app.VersionNumber)
PATH_SCRIPT  = os.path.dirname(__file__)
#  ╚╝ ╩ ╩╩╚═╩╩ ╩╚═╝╩═╝╚═╝╚═╝ VARIABLES
time_start = time.time()
# 🍉 pick excel
xcl_file = forms.pick_excel_file(title = "Select Excel File")
if not xcl_file:
    sys.exit()
# 📃 open excel
path = xcl_file
ex = Excel.ApplicationClass()
ex.Visible = False
ex.DisplayAlerts = False
# 📖 get Workbook
workbook = ex.Workbooks.Open(filename = path)
# 📕 report
ws = workbook.Sheets[1]
table = ws.Name
# methode BIMGuru
xlDirecDown = System.Enum.Parse(Excel.XlDirection, "xlDown")
xlDirecRight = System.Enum.Parse(Excel.XlDirection, "xlToRight")
xlDirecUp = System.Enum.Parse(Excel.XlDirection, "xlUp")
xlDirecLeft = System.Enum.Parse(Excel.XlDirection, "xlToLeft")
class ExcelUtils():
    def __init__(self, lstData, filepath):
        self.lstData = lstData
        self.filepath = filepath
    def importXls(self, wsName):
        ex.Visible = False
        lst_xls = []
        workbook = ex.Workbooks.Open(self.filepath)
            ws = ex.Sheets(wsName)
            wsFound = True
            ws = workbook.Worksheets[0]
            wsFound = False
        ##get number of Rows not empty ##
        rowCountF = max(ws.Range(i).End(xlDirecUp).Row for i in
                        ["A65536", "B65536", "C65536", "D65536", "E65536", "F65536", "G65536", "H65536"])
        # other method if column A is empty
        # rowCountF = ws.Range("B65536").End(xlDirecUp).Row
        # rowCountF = ws.Columns[1].End(xlDirecDown).Row
        ##get number of Coloun not empty ##
        colCountF = max(ws.Range(i).End(xlDirecLeft).Column for i in
                        ["ZZ1", "ZZ2", "ZZ3", "ZZ4", "ZZ5", "ZZ6", "ZZ7", "ZZ8", "ZZ9"])
        # other methods
        # colCountF = ws.Range("ZZ9").End(xlDirecLeft).Column
        # colCountF = ws.Rows[1].End(xlDirecRight).Column
        self.fullrange = ws.Range[ws.Cells(1, 1), ws.Cells(rowCountF, colCountF)]
        self.fullvalue = list(self.fullrange.Value2)
        # split list into sublist with number of colum
        n = colCountF
        # close Excel
        ex.Workbooks.Close()
        ex.Quit()
        # other proper way to make sure that you really closed and released all COM objects
        if workbook is not None:
            Marshal.ReleaseComObject(workbook)
        if ex is not None:
            Marshal.ReleaseComObject(ex)
        workbook = None
        ex = None
        return [list(self.fullvalue[i:i + n] for i in range(0, len(self.fullvalue), n)), wsFound]
# Try to import the excel file
    xclObj = ExcelUtils([], xcl_file)
    xclData = xclObj.importXls(table)
    result = "Import successful"
    result = "Import unsuccessful"
    xclData = [None, False]
# Output
print(xclData[0], xclData[1], result)
for raw in xclData[0]:
    for i in raw:
        print(i)
print(xclData[1])
sys.exit()
my dynamo script is “rocksolid” ( tested with 4 parameters)
here the link unwraped :wink:
I made some progress…
i am able to sort the stuff ?
where put i my transactions? have i to create a group Transaction? or transaction with subtransactions ?
i tried severial but i am still confused
2024-05-08_08h44_35
all_elements = FilteredElementCollector(doc, active_view.Id).WhereElementIsNotElementType().ToElements()
directory = forms.pick_excel_file(False, 'Select File')
wb = xlrd.open_workbook(directory)
sheet = wb.sheet_by_index(0)
data_dict = {}
element_dict = {element.Id: element for element in all_elements}
for rw in range(1, sheet.nrows):
    key = sheet.cell_value(rw, 0)
    value = sheet.row_values(rw)[1:]
    data_dict[key] = value
with Transaction(doc, __title__) as t:
    for k, v in data_dict.items():
        print("{}:{}".format(k, v))
        # this is just a print statement to show you that the value is a list
        for item in v:     # this is to loop through the list in values
            if item == '':      # if item is None type, it will skip
                continue
            element = doc.GetElement(element_dict.get(ElementId(int(k))))
            if element:
                if element.Id == ElementId(int(k)):
                    ifc_guid = element.LookupParameter("IfcGUID")
                    ifc_guid.Set(v[0]).AsString()
                    fab_type = element.LookupParameter("Fabrikationsnummer/Type")
                    fab_type.Set(v[1]).AsString()
                    write the rest of the parameter here and see what you will get
i got also this, is this related to the transaction?
@andreasd811
try to use the pyRevit Transaction handler, it is simpler:
with revit.Transaction("Transaction name"): # context manager using the pyrevit revit module Transaction, it takes care of the start/commit/disposal of transactions
        for item in v:
            if item == "":
                continue
            if element:
@Jean-Marc
i stuck at this when i run my script on my laptop
how can i convert my Instance to a Reference?
Please share the whole code so that I don’t have to feel like Indiana Jones doing some archeology :face_with_hand_over_mouth:
@Jean-Marc
here is the whole code
__title__ = "ImportExcel"
__doc__ = """Version = 1.0
Date    = 29.10.2023Version = 1.0
Date    = 29.10.2023
Description:
This is a template file for pyRevit Scripts.
How-to:
-> Click on the button
Last update:
- [24.04.2022] - 1.0 RELEASE
To-Do:
import xlrd
from Autodesk.Revit.UI.Selection import ISelectionFilter, ObjectType, Selection
clr.AddReference("System")
import time
start_time = time.time()
all_elements = FilteredElementCollector(doc).WhereElementIsNotElementType().ToElements()
data_dict = {}
# element_dict = {element.Id: element for element in all_elements}
                continue
            # element = doc.GetElement(element_dict.get(ElementId(int(k))))
            for element in all_elements:
                if element:
                        fab_typ = element.LookupParameter("Fabrikationsnummer/Type")
                        fab_typ.Set(v[1])
                        gew_beg = element.LookupParameter("Gewaehrleiszungsbeginn")
                        gew_beg.Set(v[2])
                        gew_end = element.LookupParameter("Gewaehrleiszungsende")
                        gew_end.Set(v[3])
                        herstel = element.LookupParameter("Hersteller")
                        herstel.Set(v[4])
end_time = time.time()
print('\n Laufzeit: {} Sekunden'.format(end_time - start_time))
Can you also share a Revit file and excel that is supposed to work with that?
Hard to figure out otherwise.
@Jean-Marc
i have no permission to upload a demo, it is limited to certain formats
Use a Dropbox link or zip and rename the extension
some recommendations:
Here is how I handled transactions when writing from excel to parameters. I just wrapped everything the script does in a single function process_hangers() and put the single function in the transaction to keep it simple.
clr.AddReference('Microsoft.Office.Interop.Excel')
....functions...
    excel_file = 'Inserts.xlsx'
    excel_file_path = os.path.join(script_path, excel_file)
    excel_app = Excel.ApplicationClass()
    workbook = excel_app.Workbooks.Open(excel_file_path)
    worksheet = workbook.Sheets[final_selection]
    worksheet_name = worksheet.Name
    transaction_name = "Set insert: {}".format(worksheet_name)
    ...rest of script...
    with Transaction(transaction_name, swallow_errors=True):
            process_hangers(selected_hangers)
            mlogger.error('An overall error occurred: {0}'.format(e))
        finally:
            if 'workbook' in locals():
                workbook.Close(False)
                excel_app.Quit()
                Marshal.ReleaseComObject(worksheet)
                Marshal.ReleaseComObject(excel_app)
-Note the finally and cleanup at the end to release resources after opening excel file in background
You are importing the office interop stuff, but then using xlrd.
haven’t used xlrd in a script before but the “finally” part is what I use for cleanup after background open I describe above, so not sure if it necessary with xlrd
-you collect every single element in the document and loop through them… Probably better to loop through the list of IDs in your excel file and grab only the specific elements you need. Which brings up another thing to watch out for…
-Revit makes no guarantee on the ElementId remaining stable. It could change when you change element type, it could change when somebody does a sync to central, or it could change for seemingly no reason at all.
“element.UniqueId” will not change, unless you delete the element and place a new one.
Autodesk states this in the API docs for UniqueId as well
@Jean-Marc
i hope this works, i do not use dropbox, it is forbidden :wink:
grafik
a simplified version:
import xlrd
from pyrevit import forms, revit, script, DB
output = script.get_output()
output.close_others()
with xlrd.open_workbook("H:\\_DOCS\\test.xls") as wb:
    DATA_DICT = {}
        key = int(sheet.cell_value(rw, 0))
        DATA_DICT[key] = value
    PARAMETERS = sheet.row_values(0)[1:]
def set_parameters(elements, parameters=PARAMETERS, data_dict = DATA_DICT):
    not_found = {}
    for element in elements:
        element_id = element.Id
        if element and element_id in data_dict.keys():
            element_entry = data_dict[element_id ]
            not_found[element_id] = []
            for i, parameter in enumerate(parameters[1:]):
                    element.LookupParameter(parameter).Set(element_entry[i])
                    not_found[element.Id.IntegerValue].append(parameter)
    return not_found
all_elements = DB.FilteredElementCollector(doc).WhereElementIsNotElementType().ToElements()
with revit.Transaction("Assign parameters from excel DB"):
    not_found = set_parameters(all_elements)
    print(not_found) # printing element that do not have the printed parameters
A few advices to get you further _ I am not saying my code is perfect, for from it _ :
  • You need to modularize things a bit. Create definitions whenever possible.
  • Create loops when you repeat things (getting the parameter then setting it to a value)
  • Import just the modules you need
  • Do not over comment (yes there is such thing as over-commenting, your initial code was hard to read)
  • Use what pyrevit modules have to offer (thinking about the transaction handling)
  • Handle exceptions: if the category of the element return None parameter, you need to know it and not being stopped by it.
  • learn how to use dictionaries
  • try not to mix and match Dynamo and pyRevit approaches: while similar in many aspects, they are two different beasts
@Jean-Marc
i read also cleanCode policy :wink:
i addapted your code, and it runs without error, but also without change
# 🍉 Open excelfile
#wb = xlrd.open_workbook(directory)
#sheet = wb.sheet_by_index(0)
# doc = revit.doc
with xlrd.open_workbook(directory) as wb:
    DATA_DICT = {}
# 🎯 set Parameter based excel
    not_found = {}
            element_entry = data_dict[element_id]
    return not_found
# 🔓 🔒 🔑 Set Parameter
2024-05-23_10h45_58
i changed these parts, they were logic for me
@Jean-Marc ,
the issue that i have, it happens finaly nothing…
i tested it with active view, it remains without change, any Parameter …
grafik
the excelsheet is readable
values work too
revitId als Key works too
@Jean-Marc @jpitts
the element_entry is empty
should be there not Ids
grafik
check the element_id type
maybe converting str(element_id)
@Jean-Marc ,
i think i got it
so i match to different types, it remains as ElementId i can`t convert it to a string or int ?
is there a methode?
Hard to provide you with the proper orientation
In the capture you provided, you are printing both variable types for element_id (first) and element_entry.
your element entry in the dict is a string. so converting the element_id variable to a string should do the trick when you interogate the dict key.
@Jean-Marc
so some convertion issue
in dynamo its no issue
grafik
my code so far, almost similar
# 🍉 Open excelfile
# doc = revit.doc
    DATA_DICT = {}
    d = data_dict.keys()
    not_found = {}
        element_id = int(element.Id)
        if element_id in data_dict.keys(): # element and
    return not_found
all_elements = DB.FilteredElementCollector(doc, doc.ActiveView.Id).WhereElementIsNotElementType().ToElements()
# ❗ Info
when i convert to string it remains without transaction
this is correct: str(element_id)
issue is somewhere else
