actually i am not the first who has this wish… today i did for 30 rooms one by one. delete room → place room.
__title__ = "SetBasementRooms"
__doc__ = """Version = 1.0
Date = 29.10.2023Version = 1.0
Date = 29.10.2023
Description:
This is a template file for pyRevit Scripts.
How-to:
-> Click on the button
Last update:
- [24.04.2022] - 1.0 RELEASE
To-Do:
# IMPORTS
# Regular + Autodesk
from Autodesk.Revit.UI.Selection import ISelectionFilter, ObjectType, Selection
# pyRevit
from pyrevit import script, revit, forms
# .NET Imports
clr.AddReference("System")
import time
start_time = time.time()
clr.AddReference("RevitAPI")
from System import EventHandler
from System.Windows.Forms import Form, Button, CheckBox, ComboBox, DialogResult, Label, ListView, TextBox, View
from System.Drawing import Point
from Autodesk.Revit.DB.Events import TransactionGroupAfterFailureEventArgs
from Autodesk.Revit.Exceptions import OperationCanceledException
app = __revit__.Application
selection = uidoc.Selection # type: Selection
class TestForm(Form):
def __init__(self, _doc):
self.doc = _doc
self.InitializeComponent()
def InitializeComponent(self):
self.Text = "TestForm"
self.Width = 500
self.Height = 500
self.listView1 = ListView()
self.listView1.Location = Point(10, 10)
self.listView1.Size = (300, 200)
self.listView1.CheckBoxes = True
self.Controls.Add(self.listView1)
self.cboLevel = ComboBox()
self.cboLevel.Location = Point(10, 220)
self.cboLevel.Size = (300, 20)
self.Controls.Add(self.cboLevel)
self.btnClose = Button()
self.btnClose.Location = Point(10, 250)
self.btnClose.Size = (100, 30)
self.btnClose.Text = "Close"
self.btnClose.Click += self.btnClose_Click
self.Controls.Add(self.btnClose)
self.btnOK = Button()
self.btnOK.Location = Point(120, 250)
self.btnOK.Size = (100, 30)
self.btnOK.Text = "OK"
self.btnOK.Click += self.btnOK_Click
self.Controls.Add(self.btnOK)
self.Load += self.TestForm_Load
def btnClose_Click(self, sender, args):
self.Close()
def TestForm_Load(self, sender, args):
rooms = FilteredElementCollector(self.doc).OfCategory(BuiltInCategory.OST_Rooms).WhereElementIsNotElementType().ToElements()
for room in rooms:
if room.Area > 0 and room.Location != None:
item = ListViewItem(room.Number + " - " + room.Name)
item.Tag = room
self.listView1.Items.Add(item)
levels = {}
for level in FilteredElementCollector(self.doc).OfCategory(BuiltInCategory.OST_Levels).WhereElementIsNotElementType().ToElements():
levels[level.Name] = level
self.cboLevel.DataSource = list(levels.keys())
self.cboLevel.DisplayMember = "Key"
self.cboLevel.ValueMember = "Value"
def btnOK_Click(self, sender, args):
transGroup = TransactionGroup(self.doc, "Move Rooms")
transGroup.Start()
for item in self.listView1.CheckedItems:
room = item.Tag
rmPT = room.Location.Point
roomPoint = XYZ(rmPT.X, rmPT.Y, rmPT.Z)
offset = room.get_Parameter(BuiltInParameter.ROOM_UPPER_LEVEL).AsDouble()
trans1 = Transaction(self.doc, "Unplace Room")
trans1.Start()
failOptions = trans1.GetFailureHandlingOptions()
failOptions.SetFailuresPreprocessor(UnplacedRoomWarning())
trans1.SetFailureHandlingOptions(failOptions)
room.Unplace()
trans1.Commit()
trans2 = Transaction(self.doc, "New Room")
trans2.Start()
level = self.cboLevel.SelectedItem
topo = self.doc.GetPlanTopology(level)
circuits = topo.Circuits
for circuit in circuits:
if not circuit.IsRoomLocated:
newRoom = self.doc.Create.NewRoom(room, circuit)
newRoom.get_Parameter(BuiltInParameter.ROOM_UPPER_LEVEL).Set(level.Id)
newRoom.get_Parameter(BuiltInParameter.ROOM_LOWER_OFFSET).Set(offset)
move = XYZ(roomPoint.X - rmPT.X, roomPoint.Y - rmPT.Y, rmPT.Z)
ElementTransformUtils.MoveElement(self.doc, newRoom.Id, move)
break
trans2.Commit()
transGroup.Assimilate()
self.Close()
except OperationCanceledException as ex:
except Exception as ex:
forms.alert("An error occurred: {}".format(ex))
class UnplacedRoomWarning(IFailuresPreprocessor):
def PreprocessFailures(self, failuresAccessor):
failures = failuresAccessor.GetFailureMessages()
for failure in failures:
if failure.GetSeverity() == FailureSeverity.Warning:
failureId = failure.GetFailureDefinitionId()
if failureId == BuiltInFailures.RoomFailures.RoomUnplaceWarning or failureId == BuiltInFailures.RoomFailures.RoomHeightNegative:
failuresAccessor.DeleteWarning(failure)
failuresAccessor.ResolveFailure(failure)
return FailureProcessingResult.ProceedWithCommit
return FailureProcessingResult.Continue
form = TestForm(doc)
form.ShowDialog()
i try to debug this code, here is the sourcecode in C#
i am already able to select my rooms with this:
# 🛒 classes
class ISelectionFilter_Classes(ISelectionFilter):
def __init__(self, allowed_types):
""" ISelectionFilter made to filter with types
:param allowed_types: list of allowed Types"""
self.allowed_types = allowed_types
if type(element) in self.allowed_types:
return True
# 0️⃣ PickElementsByRectangle
selected_elements = [doc.GetElement(e_id) for e_id in selection.GetElementIds()]
selected_rooms = [el for el in selected_elements if type == Room]
if not selected_rooms:
filter_types = ISelectionFilter_Classes([Room])
ref_picked_rooms = selection.PickObjects(ObjectType.Element, filter_types)
selected_rooms = [doc.GetElement(ref) for ref in ref_picked_rooms]
print("Please select a Room")
sys.exit()
currentBasement = [p.get_Parameter(BuiltInParameter.ROOM_LEVEL_ID).AsElementId() for p in selected_rooms]
print(currentBasement)
# ✅END
first how can i get rid of this error message… ?
