I’m putting together a small pyRevit toolbar for my team and want a button that just launches a Python script sitting in the same extension folder. I’ve got the bundle structure working for a basic command, but I’m unsure how the script path should be referenced so it still runs when the extension is copied to another machine. Do people usually keep the script inside the button folder and call it from the command, or place it in a shared lib folder and import it? I’m also not clear on whether the same approach works for scripts that need to touch the current Revit document versus ones that only do file work. Nothing fancy here, this is for a two-button toolbar that mostly does small cleanup tasks. If you’ve set up something similar, what layout has held up for you? Any pitfalls with paths or reloading after edits would be helpful too.
