How can i assign keyboard shortcuts for custom button?
How can I assign keyboard shortcuts for a custom button?
when I try to assign the key, created button not showing in the list.
Filter the tab you want then select the command and enter your shortcut key as you normally would:
Note:
The extension/command has to be loaded at revit startup for the command(s) to be available in this list, it is not dynamically updated.
how about extensions
Screenshot 2024-03-03 003306
