Hi all
I am trying to create a hook for a custom button I have created using pyRevit.
Is this not possible?
I go the command ID by exporting a Revit shortcuts XML file as seen below, but when I load my extension into pyRevit, it returns an error stating that my hook is invalid.
#import Revit libraries
clr.AddReference('RevitAPI')
# import libraries os and datetime
from datetime import date, time, datetime
#import pyrevit libraries
from pyrevit.revit import files
app = __revit__.Application
#document name
docName = doc.PathName
#get current date and time
now = datetime.now()
#prevent the tool, await input
mip = forms.alert("Run the script?", options = ["Yes", "No"], title = "Worksets", footer = "pyRarch")
#workset script usage file path
filepath = os.path.join(r'Z:\BPAS Staff INDEX\081 - Bayo\01_Design Technology\16_Audits\Script Usage', 'Worksets_Workset Script Usage.txt')
# process the outcome
if mip == "Yes":
if not os.path.exists(r'Z:\BPAS Staff INDEX\081 - Bayo\01_Design Technology\16_Audits\Script Usage'):
os.makedirs(r'Z:\BPAS Staff INDEX\081 - Bayo\01_Design Technology\16_Audits\Script Usage')
file = open(filepath, "a")
file.write("User= "+((os.environ.get('USERNAME')).lower()).capitalize()+" | File Path= "+docName+" | "+"Script Usage= Used the BPAS tab worksets tool | "+"Time= "+str(now)+"\n")
EXEC_PARAMS.event_args.Cancel = False
EXEC_PARAMS.event_args.Cancel = True
print("Heya please make sure you are connected to the network :D. Thank you!")
