HideCategoriesTemporary() ICollection[ElementId] error
I’m making a quick helper tool which will just temproraly hide a predefined list of categories in an active view.
I’ve tried this a few ways but get stuck with a similar error, HideCategoriesTemporary() is giving me similar errors
passing a list of elements:
expected ICollection[ElementId], got list
doc.ActiveView.HideCategoriesTemporary(
[DB.ElementId(DB.BuiltInCategory.OST_Walls,
any insights into how to get passed this?
hi
see IList<Type> problem
also, you are passing twice the wall category in your example ;p
Ah brilliant thanks! That should have it sorted
The walls cat was just a typo when I was cutting down my longer list of cats!
Heres is a solution to it,
the two spots that i got stuck on were
  • Thinking that Type in List[Type] would need to be the CLR type of the elements in the list
  • Thnking that I’d need to have a ListType instead of just passing the categories into it right away
doc.ActiveView.TemporaryViewModes.DeactivateAllModes()
cats = [
        DB.ElementId(DB.BuiltInCategory.OST_Walls),
        DB.ElementId(DB.BuiltInCategory.OST_Doors),
        # list of other categories...
cat_collection = List[DB.ElementId](cats)
doc.ActiveView.HideCategoriesTemporary(cat_collection)
@eimhin Something similar I did to hide/unhide all georef points in active view
from pyrevit import HOST_APP, DB, revit
active_view = HOST_APP.active_view
catsId = [
        DB.ElementId(DB.BuiltInCategory.OST_IOS_GeoSite),
        DB.ElementId(DB.BuiltInCategory.OST_SharedBasePoint),
        DB.ElementId(DB.BuiltInCategory.OST_ProjectBasePoint)
cat_collection = List[DB.ElementId](catsId)
# get if category is hidden in active view
cats_visibility_status = []
for cat in cat_collection:
    cats_visibility_status.append(active_view.GetCategoryHidden(cat))
with revit.Transaction('turn on Georeferenced Points'):
        if all(cats_visibility_status):
            active_view.SetCategoryHidden(cat, False)
            active_view.SetCategoryHidden(cat, True)
