Hide Linked model categories?
I was wondering, would it be possible to create a script that is able to detect linked models and turn off a specified category?
For example, assuming I have explored all the traditional Revit ways of turning things on/off, can a script be written so that it can look at all the views and turn off all the matchlines/grids from all the linked models?
Probably yes.
the Revit API to handle linked elements visibility is new and not complete, it would work with 2024+
Maybe a better / manual workflow would be to play with view templates:
  • record view templates applied to every view,
  • edit them to ā€˜not take care of the linked elements category visibility’
  • create a template that does turn off categories in links and does just that, and apply it to every view
  • re apply previous templates
Bold stuff could be done in a script to get there faster if you have to do it on multiple models, if not, manually should be faster
I came back to this because I am now starting to use Revit 2025.
Part of this intent was to hide Levels, Grids, and Matchlines. Levels and Grids i am able to hide via filters, not matchlines unless I go to each view template, set to custom…
Unfortunately, other forget to place them on proper worksets that we can turn off globally.
I was able to create this
__title__   = "Hide Linked Matchlines"
clr.AddReference("RevitAPI")
from pyrevit import revit
# Access the current Revit document, UI document, and application
doc   = revit.doc
uidoc = revit.uidoc
app   = uidoc.Application
# This list will store all valid link-based element references
# corresponding to Matchlines found inside linked Revit models
link_refs = []
# STEP 1: Collect Matchlines from all loaded Revit links
for link_inst in FilteredElementCollector(doc).OfClass(RevitLinkInstance):
    # Each RevitLinkInstance represents a loaded linked model in the project
    link_doc = link_inst.GetLinkDocument()
    if not link_doc:
        # Skip if the link is unloaded or not currently accessible
        continue
    # Collect all Matchline elements within this linked document
    matchline_ids = FilteredElementCollector(link_doc)\
        .OfCategory(BuiltInCategory.OST_Matchline)\
        .ToElementIds()
    # Skip if no Matchlines were found in this link
    if not matchline_ids:
        continue
    # For each Matchline element ID, create a cross-document Reference
    for eid in matchline_ids:
            # Get the element object from the link
            element = link_doc.GetElement(eid)
            # Create a reference that points to the linked element
            ref = Reference(element).CreateLinkReference(link_inst)
            # Add this reference to our master list for hiding
            link_refs.append(ref)
            # Some elements may fail to reference properly — ignore safely
# STEP 2: Trigger Revit’s built-in ā€œHide Elementsā€ command
if link_refs:
    # Select all collected linked Matchline references in the view
    uidoc.Selection.SetReferences(link_refs)
    # Use Revit's internal command ID for ā€œHide Elementsā€
    hide_cmd = RevitCommandId.LookupPostableCommandId(PostableCommand.HideElements)
    # This hides all currently selected elements in the active view
    app.PostCommand(hide_cmd)
I am needing help taking this up a notch by having a few modes
  • Active View: what I currently have
  • Select Views: hides them in the selected views
  • Select Sheets: hides them in the views that are on those sheets.
I haven’t been successful in the
  • Select Views and
  • Select Sheets
If anyone would like to take a stab a this and maybe get it working and share back. That would be great.
Roughly I’d say make a function (or Class) that set things for a given view.
That way you could call/use it like this:
def functionname(view):
# do the stuff here for view.
use selectfromlist pyrevit with 3 options:
  • currentview,
  • select views,
  • select sheets.
if currentview:
functioname(currentview)
elif selectviews:
for selectedview in selectviews:
functionname(selectedview)
etcetc
