I need to create the button and need to add in the shortcut keys.
then button is to hide and unhide the Linked point cloud from the current view.
Any help appreciated.
Hi Vijay,
The pyRevit guides on notion will have all the information you need to create the extension and buttons: https://www.notion.so/Create-Your-First-Command-2509b43e28bd498fba937f5c1be7f485
This explains the anatomy of an extension folder; subfolders (buttons), bundles (UI sorting and command info stored in a yaml file) and scripts in detail.
Once the button is visible on your toolbar you will be able assign it as you would any other keyboard shortcut in Revit (shortcut KS).
I got it…I need code, here it’s mine . It’s working in dynamo but not in pyrevit
# Load the Python Standard Libraries
clr.AddReference("RevitAPI")
import Autodesk
clr.AddReference("RevitNodes")
import Revit
clr.ImportExtensions(Revit.GeometryConversion)
clr.ImportExtensions(Revit.Elements)
# Current doc/app/ui
#Filtered element collector (all point clouds)
pc = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PointClouds).ToElements()
for i in pc:
cat = i.Category
if cat is not None:
t = Transaction(doc,'hide cloud')
doc.ActiveView.HideCategoryTemporary(cat.Id)
you are using library of dynamo revit , please use lib of pyrevit with document.
#Import pyRevit form library
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Category
app = __revit__.Application
doc = uidoc.Document
logger = script.get_logger()
logger.set_quiet_mode()
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PointClouds).ToElements()
cat = None
for i in collector:
cat = i.Category
if cat is not None:
thank you @Chuongpqvn…
I want to hide from the permanently with a key the unhide vice versa.
i mean want hide point cloud link from view with key and the unhide with the same key.
as in above image
This works for me to hide and show point clouds in active view in pyRevit script:
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PointClouds).WhereElementIsNotElementType()
elements = collector.ToElements()
pointclouds = collector.ToElementIds()
visible = False
for element in elements:
if not element.IsHidden(doc.ActiveView):
visible = True
break
if visible:
t = Transaction(doc,"Hide pointclouds")
doc.ActiveView.HideElements(pointclouds)
t = Transaction(doc,"Unhide pointclouds")
doc.ActiveView.UnhideElements(pointclouds)
