GetPoints for TopoSolid
Hi Everyone,
I’m having difficulty with getting all the points for a sub-divide Toposolid, in 2023 we can just use GetPoints for toposurface but it’s not available in Toposolid.
I tried using Geometry->Solid->Edge and Geometry->Lines, and use end points of all the lines, but those do not capture all the points, when the profile of the sub-divide topo has arcs or splines.
Thanks in advance
Do you have an example of such geometry?
Did you try Revit lookup on the object and digged down the geometry, solid,…?
I figure it out by filtering out the CylindricalFace :slight_smile:
