Get path from imported .dwg how?
i get some hints
it works almost well, but i get this error so, where is the issue?
doc   = __revit__.ActiveUIDocument.Document #type: Document
uidoc = __revit__.ActiveUIDocument          #type: UIDocument
app   = __revit__.Application               # Application class
def get_abs_path(cad_link_type):
	lfs = cad_link_type.GetExternalFileReference().GetLinkedFileStatus()
	if all([lfs != LinkedFileStatus.Invalid, lfs != LinkedFileStatus.NotFound]):
		return ModelPathUtils.ConvertModelPathToUserVisiblePath(cad_link_type.GetExternalFileReference().GetAbsolutePath())
cad_links = FilteredElementCollector(doc).OfClass(CADLinkType).ToElements()
cad_files = list(filter(None, map(get_abs_path, cad_links)))
OUT = cad_links, cad_files
i tested with linked and imported .dwgs i got the same error
Andreas,
I have used the following approach. I think it does what you are trying to do. It first gets the ImportInstances, then the type from that. Let me know if it is helpful.
dwgs = DB.FilteredElementCollector(revit.doc).OfClass(DB.ImportInstance).WhereElementIsNotElementType().ToElements()
    if len(dwgs) > 0: # Collector not empty
        for ii, dwg in enumerate(dwgs):
            dwg_id = dwg.Id
            dwg_name = dwg.Parameter[DB.BuiltInParameter.IMPORT_SYMBOL_NAME].AsString()
            dwg_type = doc.GetElement(dwg.GetTypeId()) # Get link type from instance
            if dwg_type.IsExternalFileReference():
                ext_ref = dwg_type.GetExternalFileReference()
                dwg_link_path  = DB.ModelPathUtils.ConvertModelPathToUserVisiblePath(ext_ref.GetAbsolutePath())
@KSalmon ,
i set also a else statment… and so it does not work :thinking:
the issue is it : to be or not to be…
does the path realy work for imported .dwg… is the filepath anywhere stored ?
here ends the topic too
Have you changed your collector to get ImportInstance instead of CadLinkType?
@KSalmon ,
i even tested linked .dwg vs imported…
i am intrested in the imported ones , i am aware its wrong, but it happend. so the project is 2 years old. i hoped, that there is anywhere stored the origin of the .dwg
My code works for getting the path of an imported DWG.
Really, @KSalmon ! you get the path tooo
@KSalmon
it remains empty
grafik
dwgs = FilteredElementCollector(revit.doc).OfClass(ImportInstance).WhereElementIsNotElementType().ToElements()
paths = []
        dwg_id = dwg.Id
        dwg_name = dwg.Parameter[BuiltInParameter.IMPORT_SYMBOL_NAME].AsString()
            dwg_link_path  = ModelPathUtils.ConvertModelPathToUserVisiblePath(ext_ref.GetAbsolutePath())
            paths.append(dwg_link_path)
print(paths)
because you are not getting passed this “if” statement. put a simple command after that like print(“Yes”) and you will see it won’t print
Just do a quick compare on import and linked dwgs and you will see for the imported dwgs all the external file refrences are not available
Sorry,
You are right
It only gets the path for those that pass the IsExternalFileReference() test
My mistake.
