Get open Sheets (UIViews) even if a View is active
Hello pyRevit Friends :slight_smile:
I have this code to get all sheets that are currently opened as windows in the project.
def OpenSheets():
    outlist = []
    uiviews = uidoc.GetOpenUIViews()
    for uiview in uiviews:
        view = doc.GetElement(uiview.ViewId)
        if view.Category.Name == "Sheets" and view.Name != "None":
            outlist.append(view)
    sorted_elements = sorted(outlist, key=lambda x: x.SheetNumber)
    return sorted_elements
My problem is that i can not get the sheet if a view on this sheet is active. Because uidoc.GetOpenUIViews() will then retrieve the active view and not the sheet.
As far as i know it is not possible to deactivate a view with the Revit API.
Is there any other workaround i can use to get my desired sheet, even if a view is active?
Appreciate any advice :slight_smile:
Kind Regards!
I’m not behind my pc anymore but could there be a solution in finding the sheets on which the views are placed if a view is open.
Don’t know if this will give you the correct set of sheets you want for your script.
you may have to check it differently.
AFAIK you don’t have a build in method for that.
But what works is that the tab is not changing name when a view is activated in a sheet:
  • I have sheet 001 opened
  • I activate a view
  • the title in the tab remains the same -Sheet title
so by checking the active view against the tab title you should get there.
reference: Solved: How can I detect activated view on sheet - Autodesk Community
Circumvolated
Oh, so MainWindowTitle was what i was looking for. This should work, will be back with results.
Thanks for your replies! :slight_smile:
Hmm, I´m struggling to get what i want.
I can get the Title of the Revit Main Window with
import System
print System.Diagnostics.Process.GetCurrentProcess().MainWindowTitle
and yes i can check this title for the string “Sheet”. But this works only for the active view/sheet.
But I can´t find out how to get the title of all open windows/tabs, thats what i would need.
This would not work because you can not tell if a view is an open view or an activated view on a sheet.
