From ForgeType to Datatype
Ok - so how does one go from ForgeTypeId (spec) to a DATATYPE you can use in a Shared Parameter file?
You can’t just use the text as both of these (and maybe more?) have an additional prefix… In this case HVAC_
Then YesNo needs to be parsed to YESNO - not YES_NO like others with camel case.
Or is this just one of those tedious thing in Revit API? (once upon a time it was simple…)
autodesk.spec.aec.energy:thermalConductivity-2.0.0
Thermal Conductivity
THERMAL_CONDUCTIVITY
autodesk.spec.aec.structural:thermalExpansionCoefficient-2.0.0
Thermal Expansion Coefficient
THERMAL_EXPANSION_COEFFICIENT
from Autodesk.Revit import DB
from Autodesk.Revit.DB import LabelUtils
import System
import re
flags = System.Reflection.BindingFlags.Public | System.Reflection.BindingFlags.Static
name_map = {}
def add_names(dotnet_type, prefix=""):
    for p in dotnet_type.GetProperties(flags):
            val = p.GetValue(None, None)
            name_map[val.TypeId] = prefix + p.Name
# Build mapping
add_names(clr.GetClrType(DB.SpecTypeId))
add_names(clr.GetClrType(DB.SpecTypeId.Boolean))
add_names(clr.GetClrType(DB.SpecTypeId.Int))
add_names(clr.GetClrType(DB.SpecTypeId.String))
add_names(clr.GetClrType(DB.SpecTypeId.Reference))
def to_clean(name):
    if not name:
        return "UNKNOWN"
    s1 = re.sub(r'(.)([A-Z][a-z]+)', r'\1_\2', name)
    s2 = re.sub(r'([a-z0-9])([A-Z])', r'\1_\2', s1)
    if s2 == "Yes_No":
        s2 = "YESNO"
    return s2.replace(" ", "").upper()
results = set()
for spec_id in DB.SpecUtils.GetAllSpecs():
    raw = name_map.get(spec_id.TypeId, "")
    forge = spec_id.TypeId
    forgename = LabelUtils.GetLabelForSpec(spec_id)
    myname = to_clean(raw)
    results.add((myname, forgename, forge))
for r in sorted(results):
    print("------")
    print(r[2])
    print(r[1])
    print(r[0])
    print("------")
Try
UnitUtils.GetTypeCatalogStringForSpec(spec_id)
No go. UnitUtils is for unit ForgetType, not spec types.
I see that UnitUtils only includes the ones with units - makes sense sort of given the name. Running this there are only 10 exceptions for which your to_clean() function will work. Instead of the try/except you could check “IsMeasurableSpec”. Anyway deals with all the HVAC_* and the like.
    UnitUtils,
    LabelUtils,
    SpecUtils,
def forgetype_to_datatype():
    print("Print all specs")
    results = set()
    # spec_ids = UnitUtils.GetAllMeasurableSpecs()
    # spec_ids = UnitUtils.GetAllSpecs()
    spec_ids = SpecUtils.GetAllSpecs()
    print(len(spec_ids))
    for spec_id in spec_ids:
            myname = UnitUtils.GetTypeCatalogStringForSpec(spec_id)
            myname = "not measurable"
        print(r[2])
        print(r[1])
        print(r[0])
        print("------")
if __name__ == '__main__':
Thanks, between the two and some cleanup, I think I can get where I need to be.
Looks like the older datatypes are just being interpreted under the hood from the shared param file. Time for a 2.0 param file format. Probably JSON to one can add in localization to shared params.
