Forms.alert() source code
Just to confirm, forms.alert() doesnt use an xaml UI, correct? The source code seems to calls the default revit api UI.Taskdialog, so no way of changing the xaml. Thanks
def alert(msg, title=None, sub_msg=None, expanded=None, footer='',
          ok=True, cancel=False, yes=False, no=False, retry=False,
          warn_icon=True, options=None, exitscript=False):
    r"""Show a task dialog with given message.
    Args:
        msg (str): message to be displayed
        title (str, optional): task dialog title
        sub_msg (str, optional): sub message, use html to create clickable links
        expanded (str, optional): expanded area message
        footer (str, optional): footer text
        ok (bool, optional): show OK button, defaults to True
        cancel (bool, optional): show Cancel button, defaults to False
        yes (bool, optional): show Yes button, defaults to False
        no (bool, optional): show NO button, defaults to False
        retry (bool, optional): show Retry button, defaults to False
        warn_icon (bool, optional): show warning icon
        options (list[str], optional): list of command link titles in order
        exitscript (bool, optional): exit if cancel or no, defaults to False
    Returns:
        (bool): True if okay, yes, or retry, otherwise False
    Examples:
        ```python
        forms.alert('Are you sure?',
                    sub_msg='<a href=\"https://discourse.pyrevitlabs.io/ \">Click here if you are not sure and want to go to the pyRevit Forum</a>',
                    ok=False, yes=True, no=True, exitscript=True)
    # BUILD DIALOG
    cmd_name = EXEC_PARAMS.command_name
    if not title:
        title = cmd_name if cmd_name else 'pyRevit'
    tdlg = UI.TaskDialog(title)
    # process input types
    just_ok = ok and not any([cancel, yes, no, retry])
    options = options or []
    # add command links if any
    if options:
        clinks = coreutils.get_enum_values(UI.TaskDialogCommandLinkId)
        max_clinks = len(clinks)
        for idx, cmd in enumerate(options):
            if idx < max_clinks:
                tdlg.AddCommandLink(clinks[idx], cmd)
    # otherwise add buttons
        buttons = coreutils.get_enum_none(UI.TaskDialogCommonButtons)
        if yes:
            buttons |= UI.TaskDialogCommonButtons.Yes
        elif ok:
            buttons |= UI.TaskDialogCommonButtons.Ok
        if cancel:
            buttons |= UI.TaskDialogCommonButtons.Cancel
        if no:
            buttons |= UI.TaskDialogCommonButtons.No
        if retry:
            buttons |= UI.TaskDialogCommonButtons.Retry
        tdlg.CommonButtons = buttons
    # set texts
    tdlg.MainInstruction = msg
    tdlg.MainContent = sub_msg
    tdlg.ExpandedContent = expanded
    if footer:
        footer = footer.strip() + '\n'
    tdlg.FooterText = footer + 'pyRevit {}'.format(
        versionmgr.get_pyrevit_version().get_formatted()
    tdlg.TitleAutoPrefix = False
    # set icon
    tdlg.MainIcon = \
        UI.TaskDialogIcon.TaskDialogIconWarning \
        if warn_icon else UI.TaskDialogIcon.TaskDialogIconNone
    # tdlg.VerificationText = 'verif'
    # SHOW DIALOG
    res = tdlg.Show()
    # PROCESS REPONSES
    # positive response
    mlogger.debug('alert result: %s', res)
    if res == UI.TaskDialogResult.Ok \
            or res == UI.TaskDialogResult.Yes \
            or res == UI.TaskDialogResult.Retry:
        if just_ok and exitscript:
            sys.exit()
        return True
    # negative response
    elif res == coreutils.get_enum_none(UI.TaskDialogResult) \
            or res == UI.TaskDialogResult.Cancel \
            or res == UI.TaskDialogResult.No:
        if exitscript:
            sys.exit()
            return False
    # command link response
    elif 'CommandLink' in str(res):
        tdresults = sorted(
            [x for x in coreutils.get_enum_values(UI.TaskDialogResult)
             if 'CommandLink' in str(x)]
        residx = tdresults.index(res)
        return options[residx]
    elif exitscript:
        sys.exit()
        return False
Hi @Kervin, you’re correct, it uses revit taskdialog so there’s no xaml to modify.
Thanks Andrea
By the way, does the print output window also use xaml? It seems so tantalizing to modify like forms.alert() and selectfromlist. Thanks
Yes, but it is handled on the .net side, so it is compiled and not editable at runtime.
