File path to a file
Hi all!
I think my issue is quit for dummies’’ so sorry in advance##
i have a cod that part of his operation is to load a title block to the revit file.
the same with a shared parameter txt file’ that loads the sp to the project file.
so far so good now, both files located in a kind of helpers modules, located inside the pyrevit extensions,
i call this files using the path of my machine as -
ttblock_file = r"C:\Users\Dotan\Desktop\MyExtension\ListGen_master.lib\revit\ListGen_TitleBlock.rfa"
now, how can i set this path’s so that they will fit in my client’s machine ?
try’s with os module and got lost…
I’m adding my code
help will be highly appreciated
def LoadTTblockIfMissing(titleBlcName, wasRun = False):
    TBCollector = FilteredElementCollector(doc).OfClass(FamilySymbol)
    TBCollector.OfCategory(BuiltInCategory.OST_TitleBlocks).ToElements()
    TBElementList = TBCollector.ToElements() #list of elements
    #get defult title block
    for tb in TBElementList:
        tbName = [tb.FamilyName for tb in TBElementList] #list of elements names
        if titleBlcName not in tbName:
            transaction = Transaction(doc, "load family")
            transaction.Start()
            ttbfile = doc.LoadFamily(ttblock_file)
            transaction.Commit()
            wasRun == True
            wasRun = 'File Exsist'
    return wasRun
#=========== STARTS CODE ================================
# Exmple ======================================================
stb = LoadTTblockIfMissing('ListGen_TitleBlock', wasRun = False)
    # open up the sp file from disc at given path - must have in order to open in revit
    path = r"C:\Users\Dotan\Desktop\MyExtension\ListGen_master.lib\proced\ListGen_SharedParameter.txt"
    fileExist = System.IO.File.Exists(path)
    openRead = System.IO.File.OpenRead(path)
    df = DefinitionFile
    def df(application, fileName):
        application.SharedParametersFilename = fileName
        return application.OpenSharedParameterFile()
    spf = df(app, path)
    exp = sp.IsSharedParamExist(spf)
    indxList = exp[0]
    spParamList = exp[1]
    # in case of runing the code again with difrent category
    indx =  [idx for idx, value in enumerate(exp[1])]
    splist = exp[1]
    asp = sp.AddSharedParamToProject(indx, splist)
Sounds like you need to use user’s environmental variables. For example below is a path to a CSV file called “Space Names.csv” on any users desktop
filepath = os.path.join(os.environ["USERPROFILE"],"Desktop", "Space Names.csv")
Search working with environment variables in python for more examples…
Also you can do it this way:
from os.path import expanduser
homepath = expanduser("~")
filepath = homepath + "\\Desktop\\ListGen_TitleBlock.rfa"
or like this:
homepath = os.getenv('HOME')
