File Path for Linked CAD
I’m trying to create a tool that re-path Linked CAD. However, I am stuck on getting the file path of the import instances (it’s part of the workflow), which confuses me because I use the same method in Dynamo Python and it works…
Here is my code:
dwgs = DB.FilteredElementCollector(revit.doc)\
             .OfClass(DB.ImportInstance)\
             .ToElements()
for dwg in dwgs:
    if dwg.IsLinked:
        Ref = dwg.GetExternalFileReference()
and the error I got is “This Element does not represent an external file.”
Hi
Would you mind posting the whole code and the stack trace to make sure where the error is.
I believe your collector is incorrect -
I had written this code a while back - check if this works for you
allcadlinks = list(FilteredElementCollector(doc).\
                   OfClass(CADLinkType).\
                   WhereElementIsElementType().ToElements())
for cadlink in allcadlinks:
    file_path = cadlink.GetExternalFileReference().GetPath()
    file_path = ModelPathUtils.ConvertModelPathToUserVisiblePath(file_path)
Awesome! Works perfectly! Thanks you!
