Feature request: ReValue. It would be extremely usefull to be able to change Text Notes with ReValue.
the value parameter is not available right now
I think it is not so straightforward as it seems. I tinkered with text notes once, and it is quite complicated due to formatting and stuff.
its a very crude version but it works.
it will probably remove any formating indeed, but it was a good exercise.
I added Line: 78, 79, 121, 122, 166, 167
"""Reformat parameter string values (Super handy for renaming elements)"""
#pylint: disable=E0401,W0703,W0613
import re
from pyrevit import coreutils
from pyrevit import revit, DB
class ReValueItem(object):
def __init__(self, eid, oldvalue, final=False):
self.eid = eid
self.oldvalue = oldvalue
self.newvalue = ''
self.final = final
self.tooltip = ''
def format_value(self, from_pattern, to_pattern):
if to_pattern is None:
to_pattern = ""
if from_pattern:
# if format contains pattern finders use reformatter
if any(x in from_pattern for x in ['{', '}']):
self.newvalue = \
coreutils.reformat_string(self.oldvalue,
from_pattern,
to_pattern)
self.tooltip = '{} --> {}'.format(from_pattern, to_pattern)
# otherwise use a simple find/replacer
self.newvalue = \
re.sub(from_pattern, to_pattern, self.oldvalue)
self.tooltip = 'No Conversion Specified'
self.newvalue = ''
except Exception:
self.newvalue = ''
class ReValueWindow(forms.WPFWindow):
# create pattern maker window and process options
forms.WPFWindow.__init__(self, xaml_file_name)
self._target_elements = revit.get_selection().elements
self._reset_preview()
self._setup_params()
@property
def selected_param(self):
return self.params_cb.SelectedItem
@property
def old_format(self):
return self.orig_format_tb.Text
@old_format.setter
def old_format(self, value):
self.orig_format_tb.Text = value
@property
def new_format(self):
return self.new_format_tb.Text
@property
def preview_items(self):
return self.preview_dg.ItemsSource
@property
def selected_preview_items(self):
return self.preview_dg.SelectedItems
def _setup_params(self):
unique_params = set()
for element in self._target_elements:
# grab element parameters
if element.GetType().ToString() == "Autodesk.Revit.DB.TextNote":
unique_params.add("Text")
for param in element.Parameters:
if not param.IsReadOnly \
and param.StorageType == DB.StorageType.String:
unique_params.add(param.Definition.Name)
# grab element family parameters
# if element.Family:
# for param in element.Family.Parameters:
# if not param.IsReadOnly \
# and param.StorageType == DB.StorageType.String:
# unique_params.add(
# 'Family: {}'.format(param.Definition.Name)
all_params = ['Name', 'Family: Name']
all_params.extend(sorted(list(unique_params)))
self.params_cb.ItemsSource = all_params
self.params_cb.SelectedIndex = 0
def _reset_preview(self):
self._revalue_items = []
self.preview_dg.ItemsSource = self._revalue_items
def _refresh_preview(self):
self.preview_dg.Items.Refresh()
def on_param_change(self, sender, args):
old_value = ''
if self.selected_param == 'Name':
old_value = revit.query.get_name(element)
elif self.selected_param == 'Family: Name':
if hasattr(element, 'Family') and element.Family:
old_value = revit.query.get_name(element.Family)
# elif 'Family:' in self.selected_param:
# pname = self.selected_param.replace('Family: ', '')
# param = element.Family.LookupParameter(pname)
# if param:
# old_value = param.AsString()
elif self.selected_param == 'Text':
old_value = element.Text
param = element.LookupParameter(self.selected_param)
if param:
newitem = ReValueItem(eid=element.Id, oldvalue=old_value)
newitem.format_value(self.old_format,
self.new_format)
self._revalue_items.append(newitem)
self._refresh_preview()
def on_format_change(self, sender, args):
for item in self._revalue_items:
if not item.final:
self.new_format)
def on_selection_change(self, sender, args):
if self.preview_dg.SelectedItems.Count == 1 \
and not self.new_format:
self.old_format = self.preview_dg.SelectedItem.oldvalue
def mark_as_final(self, sender, args):
selected_names = [x.eid for x in self.selected_preview_items]
if item.eid in selected_names:
item.final = True
def apply_new_values(self, sender, args):
self.Close()
with revit.Transaction('ReValue {}'.format(self.selected_param),
log_errors=False):
if item.newvalue:
element = revit.doc.GetElement(item.eid)
element.Name = item.newvalue
if element.Family:
element.Family.Name = item.newvalue
element.Text = item.newvalue
if param:
param.Set(item.newvalue)
except Exception as ex:
forms.alert(str(ex), title='Error')
ReValueWindow('ReValueWindow.xaml').show(modal=True)
You could PR that on Github for the Revalue
