Extending Revit API Classes with IronPython?
I have learned that in C#, one can extend a class, adding new methods without needing to subclass or wrap the class, right? And I’ve heard that one can do this to Revit API classes.
Is there a way to do this in IronPython? I have searched the web and not found anything.
Yes. What are you looking to do?
clr.AddReference("System.Windows.Forms")
from System.Windows.Forms import Form
# Extending the .NET 'Form' class
class MyExtendedForm(Form):
    def __init__(self):
        super().__init__()
        self.Text = "Extended .NET Form in Python"
    # Overriding a .NET method
    def OnClick(self, event):
        print("Form clicked!")
        super().OnClick(event)
Thank you for the response!
However, if it wasn’t clear, I’m asking about extending specifically a Revit API class (such as Element). Also, I don’t think that I want to subclass because then if I passed the subclassed element back to Revit as an argument, then the API would not see it as an instance of the original class, right?
I have seen some demonstrations of extending Revit API classes through C#, which uses a special syntax native to C#, which doesn’t subclass, but rather adds methods to the original class. See this video by Aussie BIM Guru:
https://www.youtube.com/watch?v=i7v_HPurJQw
Is there some way to do this in IronPython without subclassing/inheriting?
Updated findings:
According to the IronPython docs, “Extension methods are currently not natively supported by IronPython. Hence, they cannot be invoked like instance methods. Instead, they have to be invoked like static methods.”
I’m not 100% sure what that means, but I assume there is no direct and easy way to use extension methods, even though IronPython is written in C#, which has them.
My next thought was to code all the extension methods in C#, then import them into IronPython. I found examples that do exactly that, and so I attempted it. It worked! Create a C# static class like this, following the standard practice for extension methods in C#:
using Autodesk.Revit.DB;
namespace ExtensionMethods
    public static class Element_Ext
        public static string ExtensionTest(this Element elem)
            return elem.Name + " Extension Method Test";
Then import that into IronPython by first importing it from the namespace, then using clr.ImportExtensions on the extension method itself:
clr.AddReferenceToFileAndPath(r"...ExtensionMethodsProject\bin\Debug\net8.0\ExtensionMethodsProject.dll")
from ExtensionMethods import Element_Ext
clr.ImportExtensions(Element_Ext)
# Now you can call the extension method on any instance of the extended class
print a_revit_API_Element.ExtensionTest() # prints "{Element.Name} Extension Method Test"
This is very cool, but unfortunately, there are problems. I created the C# project using .NET 8, so it does not work in older versions of Revit. I would have to build different versions of the dll for the different versions of Revit. Also, there is probably a better way to add the dll reference within IronPython so that it doesn’t rely on an absolute path to the dll, but I don’t know how to do this. Referencing an absolute path obviously won’t work when deploying my pyRevit extension to multiple users.
So, unfortunately, I don’t think I will be using these extension methods because it ended up being more complex than the python wrapper class I was originally using for this functionality. The whole point was to simplify my development cycle, but now that I am working with multiple languages, targeting multiple .NET versions and multiple Revit versions, re-compiling, and re-deploying with every change, the advantage is no longer there. Shame!
(If I could find a way to use extension methods directly in IronPython, then I totally would!)
