Hello everyone
I’m trying to export a schedule to JSON format instead of CSV
I read that it can be done using pyRevit, but couldn’t find specific instructions
Would appreciate any help
Thank u
Hello everyone
Thank u
@RotemMidved Hi, and welcome
you will find what you need with this link script module - dump_json / load_json- pyRevit
Merci beaucoup Jean-Marc
So this is the code i guess to perform the action i want
Can u direct me to where i can find information and help on how to implement this?
Greetings
Usually when you expand the source code in the link I provided you get more info about inputs, output and eventually code samples.
you can also look for similar code in the pyrevit codebase like so Code search results and get lucky
if not, enlarge your search in github Code search results
second result is close enough in this example
here is a dumb sample
data = {"menu": {
"id": "file",
"value": "File",
"popup": {
"menuitem": [
{"value": "New", "onclick": "CreateNewDoc()"},
{"value": "Open", "onclick": "OpenDoc()"},
{"value": "Close", "onclick": "CloseDoc()"}
json_filepath = "C:\......"
script.dump_json(data, json_filepath)
