Can PyRevit be used to export 3D geometry??
The question should read:
Can Revit export to some kind of 3D formats?
Short answer: Yes
Longer answer: to IFC, SAT, FBX, … yes
a commented example from Data-shapes github repo to export to FBX, it is from a dynamo custom node in python https://github.com/MostafaElAyoubi/Data-shapes/blob/master/Nodes/Export%20to%20FBX.dyf
#Data-Shapes www.data-shapes.net`
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
t = Transaction(doc,'export')
t.Start() # could be handled differently with pyrevit module with Transaction('do something')
def tolist(input):
if isinstance(input,list):
return input
return [input]
folder = IN[0] # to be change to grad the destination folder
prefix = IN[1] # no use in the code
views = tolist(IN[2]) # to be change to grad the list of views to export
result = []
vset = ViewSet()
for v in views: # meant to iterate on a list of views to be exported
vset.Insert(UnwrapElement(v))
result.append(doc.Export(folder,UnwrapElement(v).Name,vset,FBXExportOptions()))
OUT = 'Success' # no use in pure python
or in C# from the building coder samples
pretty much the same structure
When I use FBXExportOptions, I lose all materials. In an Autodesk forum, I got a response that these days more people use the CustomExporter. So presently I’m trying to find a minimal example of creating an FBX file with the CustomExporter. Does anyone know of one?
At present, CustomExporter is confusing me. It seems to assume that I by and large need to write the output file mesh by mesh. With the previous but apparently dated FBXExportOptions, it was very intuitive. Unity is much the same way:
public static void ExportGameObjects(Object[] objects)
string filePath = Path.Combine(Application.dataPath, "MyGame.fbx");
ModelExporter.ExportObjects(filePath, objects);
It seems like the Revit API is very low-level for these operations now, unless I’m missing something. Which is probable. I’m new to the Revit API, but not very new to graphics, file formats, etc.
@corybarr How did you get on with this? Did you roll your own?
