Hi Community,
Is that possible to use Python to export element parameters/data from Revit into csv files either inside of Revit program or without opening the program? I would like to discuss both ways. Appreciated!
Hi Community,
i managed first doing it in dynamo it is easy going
i python i come until collecting, BUT not the export…
it would be recommonadable to make some kind of interface to get and set CSV
# PythonCode
__title__ = "Export CSV"
__author__ = "Andreas Draxl"
__version__ = "1.0"
__doc__ = "Version = 1.1"
#Date = "28.06.2023"
from pyrevit import revit
clr.AddReference("System.Windows.Forms")
clr.AddReference("System")
from System.Windows.Controls import ComboBoxItem
import wpf
PATH_SCRIPT = os.path.dirname(__file__)
uidoc = revit.uidoc
app = revit.app
name = "Export CSV"
transaction = Transaction(doc, name)
transaction.Start()
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType()
walls = list(collector)
output = []
for wall in walls:
length_param = wall.LookupParameter("Länge")
if length_param and length_param.StorageType == StorageType.Double:
length = length_param.AsDouble()
length_mm = UnitUtils.ConvertFromInternalUnits(length, DisplayUnitType.DUT_MILLIMETERS)
output.append(length_mm)
transaction.Commit()
# Export to CSV
if output:
csv_file_path = os.path.join(PATH_SCRIPT, "output.csv")
with open(csv_file_path, "w") as f:
f.write("Length (mm)\n")
for value in output:
f.write(f"{value}\n")
TaskDialog.Show("Export Successful", f"CSV file exported to: {csv_file_path}")
TaskDialog.Show("No Walls", "No walls found in the project.")
print(output)
i get this warning ![]()
KR
Andreas
add this at the beginning of your file
# -*- coding: UTF-8 -*-
when using ascii characters in string you have to specify the encoding.
if you want to have a path setting UI, use the forms module
note that you have two written functions for csv in the script module
load_csv and dump_csv
