Do you have this error when you use OS Lib? If i delete OS dir and past string path to “open json” all goes without problem…
My “error” code:
from rpw import revit
import json
uidoc = revit.uidoc
def __init__(self, nom_categorie):
self.nom_categorie = nom_categorie
def AllowElement(self, e):
if e.Category.Name in self.nom_categorie:
# if self.nom_categorie.Contains(e.Category.Name):
# if e.Category.Name == self.nom_categorie:
return True
return False
return True
def pick_objects(title="Pick", filter=""):
with forms.WarningBar(title=title):
return uidoc.Selection.PickObjects(ObjectType.Element, CustomISelectionFilter(filter))
dir = os.path.dirname(os.path.abspath(__file__))
# Pick schacko element
air_terminal = pick_objects(title="Pick schacko DQJ", filter="Air Terminals")
# Write air flow
air_flow = forms.ask_for_string(prompt="Write air supply", title="Insulation")
air_flow = round(float(air_flow), -1)
air_flow = int(air_flow)
print(air_flow)
# Get DQJ sizes
with open(os.path.join(dir, "schacko_DQJ_sq_supply.json")) as file:
dqj_dict = json.load(file)
print(dqj_dict[str(air_flow)])
selected_dqj = forms.SelectFromList.show(dqj_dict[str(
air_flow)], title="Select DQJ which you want to pick", multiselect=False, button_name='Select DQJ')
selected_dqj_size = selected_dqj[0][3::]
print(selected_dqj_size)
String path…
with open("C:\Users\pawel\Documents\GitHub\PYLAB\PYLAB.extension\PYLAB.tab\DuringTests.Panel\DQJ_Calc.pushbutton\schacko_DQJ_sq_supply.json", "r") as file:
