I start the ManageSharedParameters app and get the error below. Please help. Thank you.
File "C:\Users\ek01\AppData\Roaming\pyRevit\Extensions\PyRevitMEP.extension\pyRevitMEP.tab\Manage.panel\Parameters.stack\ManageSharedParameter.pushbutton\script.py", line 10, in <module>
File "C:\Users\ek01\AppData\Roaming\pyRevit\Extensions\PyRevitMEP.extension\lib\pyrevitmep\parameter\manageshared.py", line 9, in <module>
ImportError: Cannot import name ParameterType
IronPython.Runtime.Exceptions.ImportException: Cannot import name ParameterType
at IronPython.Runtime.Importer.ImportFrom(CodeContext context, Object from, String name)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`4.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run1[T0,TRet](T0 arg0)
at IronPython.Runtime.PythonContext.InitializeModule(String fileName, ModuleContext moduleContext, ScriptCode scriptCode, ModuleOptions options)
at IronPython.Runtime.Importer.LoadModuleFromSource(CodeContext context, String name, String path)
at IronPython.Runtime.Importer.LoadFromDisk(CodeContext context, String name, String fullName, String str)
at IronPython.Runtime.Importer.ImportFromPathHook(CodeContext context, String name, String fullName, List path, Func`5 defaultLoader)
at IronPython.Runtime.Importer.ImportFromPath(CodeContext context, String name, String fullName, List path)
at IronPython.Runtime.Importer.ImportNestedModule(CodeContext context, PythonModule module, String[] parts, Int32 current, List path)
at IronPython.Runtime.Importer.ImportModuleFrom(CodeContext context, Object from, String[] parts, Int32 current)
at IronPython.Runtime.Importer.ImportModule(CodeContext context, Object globals, String modName, Boolean bottom, Int32 level)
at IronPython.Modules.Builtin.__import__(CodeContext context, String name, Object globals, Object locals, Object fromlist, Int32 level)
at IronPython.Runtime.Importer.ImportLightThrow(CodeContext context, String fullName, PythonTuple from, Int32 level)
