Error message in 25 and 26, loads in 23, 24, 27
Unrelated to original thread: I managed to fix my errors, had to remove the dev clone completely and set it up again using CLI 6.4.
I guess someting was cached that I could not pinpoint. :man_shrugging:
Right now I’ve got older versions: R25.4 and R26.4
Weirdly enough, I still had ArchSmarter installed in 25
pyRevit R25
If I understand the IT guy correctly (my interpretation), he said pyRevit and another program/add-in were looking for/to use the same file at the same time, and they can’t use them simultaneously. He also said that Autodesk has no plan to fix it for 25/26, but Revit 27 has the ability to find/use older versions so there won’t be a conflict.
I opened R27 and pyRevit does not load in R27, which it did before. I’m assuming it’s because as you said, the older version of pyRevit isn’t compatible.
You mention a new loader, is that in Revit or pyRevit?
New Loader is part of pyRevit 6+, you can disable it in the settings. It speeds up loading time. Starting pyRevit 7, the old loader will (very likely) no longer be available.
Just wanted to follow up on this topic since I uploaded pyRevit 7.0 and it was causing problems on my laptop as well. With the help of CHat GPT, here is what resolved it:
Hopefully that helps someone else having the same problem.
