Erro ao clicar selecionar (pick)
File “C:\Program Files\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Selection.panel\Pick.splitpushbutton\Pick.pushbutton\script.py”, line 62, in
File “C:\Program Files\pyRevit-Master\pyrevitlib\pyrevit\forms\_init_.py”, line 720, in show
File “C:\Program Files\pyRevit-Master\pyrevitlib\pyrevit\forms\_init_.py”, line 677, in _init_
AttributeError: ‘module’ object has no attribute ‘ResourceReferenceKeyNotFoundException’
System.MissingMemberException: ‘module’ object has no attribute ‘ResourceReferenceKeyNotFoundException’
at Microsoft.Scripting.Runtime.LightExceptions.ThrowException(LightException lightEx)
at Microsoft.Scripting.Runtime.LightExceptions.CheckAndThrow(Object value)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`2.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run7[T0,T1,T2,T3,T4,T5,T6,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`9.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run9[T0,T1,T2,T3,T4,T5,T6,T7,T8,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6, T7 arg7, T8 arg8)
at CallSite.Target(Closure, CallSite, CodeContext, Object, Object, Object, Object, Object, Object)
at IronPython.Runtime.Types.PythonType.FastTypeSite`5.CallTarget(CallSite site, CodeContext context, Object type, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
at Microsoft.Scripting.Interpreter.DynamicInstruction`8.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run6[T0,T1,T2,T3,T4,T5,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5)
at Microsoft.Scripting.Interpreter.DynamicInstruction`6.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run5[T0,T1,T2,T3,T4,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
at System.Dynamic.UpdateDelegates.UpdateAndExecute4[T0,T1,T2,T3,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3)
at Microsoft.Scripting.Interpreter.DynamicInstruction`5.Run(InterpretedFrame frame)
at IronPython.Compiler.PythonScriptCode.Run(Scope scope)
Buon dia,
Fixed in latest wip.
Go to pyRevitlabs.io and use the orange button
Bom dia Jean-Marc , fui ao pyRevitlabs.io, e não encontrei botão laranja!
Teria uma forma mais acessível , poderia mandar o link da solução
Muito obrigado
https://github.com/pyrevitlabs/pyRevit/actions/runs/22315555733/artifacts/5620751622
