Does anyone know how to change the CropBox Lineweight through the api? To accomplish this manually the only way I know of is to select the CropBox, right click and select “Override Graphics in View” → “By Element”. Make sure thin lines is turned off. The tedious part is doing this on many Interior Elevation CropBoxes.
Something rough I did a while back:
from pyrevit import revit, DB, forms, script
output = script.get_output()
output.close_others()
views = DB.FilteredElementCollector(doc).OfCategory(
DB.BuiltInCategory.OST_Views).WhereElementIsNotElementType().ToElements()
views_on_sheet = []
for v in views:
if v.get_Parameter(DB.BuiltInParameter.VIEWER_SHEET_NUMBER).AsString() != '':
views_on_sheet.append(v)
selected_views = forms.SelectFromList.show(
views_on_sheet, button_name='Select Views', multiselect=True, name_attr='Name')
lineweights = range(1, 17, 1)
selected_lineweight = forms.SelectFromList.show(
lineweights, button_name='Select Lineweight', multiselect=False, height=475)
if selected_lineweight and selected_views:
override = DB.OverrideGraphicSettings().SetProjectionLineWeight(selected_lineweight)
with revit.TransactionGroup('Set Viewport Lineweight'):
for view in selected_views:
with revit.Transaction('TEMP crop box to false'):
view.CropBoxVisible = False
collector = DB.FilteredElementCollector(doc, view.Id)
shownElems = collector.ToElementIds()
with revit.Transaction('TEMP crop box to true'):
view.CropBoxVisible = True
collector.Excluding(shownElems)
cropBoxElement = collector.FirstElement()
if cropBoxElement:
with revit.Transaction('Set Viewport Lineweight'):
view.SetElementOverrides(cropBoxElement.Id, override)
script.exit()
Thanks for your reply. So it appears the issue is getting the cropbox Id. I am wondering why CropBox.Id does not work. Your method of comparing a collector list with and without the cropbox visible makes sense. I tried that and it worked for one of the views, but it did not work for the other three. I will have to dig in some more to see what is going on for the other three views on the elevation marker.
It appears that the CropBox.Id is 1 less than the View.Id. This worked for all of the views on the elevation marker. This might be a risky method, but seems to work as of now.
cb_id = view.Id.IntegerValue - 1
cb_id = DB.ElementId(cb_id)
Apply the override settings to the crop box
view.SetElementOverrides(cb_id, override_settings)
