The following error reports when running any of the list template items on EF Tools.
File "C:\Users\Kevin\AppData\Roaming\pyRevit\Extensions\pyChilizer.extension\pyChilizer.tab\Template.panel\template1.stack\List Filled Regions.pushbutton\script.py", line 4, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\__init__.py", line 36, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\db\__init__.py", line 19, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\db\view.py", line 10, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\db\collector.py", line 35, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\ui\__init__.py", line 1, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\ui\forms\__init__.py", line 12, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\ui\forms\flexform.py", line 6, in <module>
File "C:\Program Files\pyRevit-Master\pyrevitlib\rpw\ui\forms\resources.py", line 46, in <module>
IOError: System.IO.IOException: Could not add reference to assembly IronPython.Wpf
at IronPython.Runtime.ClrModule.AddReference(CodeContext context, String name)
at IronPython.Runtime.ClrModule.AddReference(CodeContext context, Object[] references)
at Microsoft.Scripting.Interpreter.ActionCallInstruction`2.Run(InterpretedFrame frame)
at IronPython.Compiler.Ast.CallExpression.Invoke1Instruction.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run1[T0,TRet](T0 arg0)
at IronPython.Runtime.PythonContext.InitializeModule(String fileName, ModuleContext moduleContext, ScriptCode scriptCode, ModuleOptions options)
at IronPython.Runtime.Importer.LoadModuleFromSource(CodeContext context, String name, String path)
at IronPython.Runtime.Importer.LoadFromDisk(CodeContext context, String name, String fullName, String str)
at IronPython.Runtime.Importer.ImportFromPathHook(CodeContext context, String name, String fullName, List path, Func`5 defaultLoader)
at IronPython.Runtime.Importer.ImportFromPath(CodeContext context, String name, String fullName, List path)
at IronPython.Runtime.Importer.ImportNestedModule(CodeContext context, PythonModule module, String[] parts, Int32 current, List path)
at IronPython.Runtime.Importer.ImportModuleFrom(CodeContext context, Object from, String[] parts, Int32 current)
at IronPython.Runtime.Importer.ImportModule(CodeContext context, Object globals, String modName, Boolean bottom, Int32 level)
at IronPython.Modules.Builtin.__import__(CodeContext context, String name, Object globals, Object locals, Object fromlist, Int32 level)
at IronPython.Runtime.Importer.ImportLightThrow(CodeContext context, String fullName, PythonTuple from, Int32 level)
at IronPython.Runtime.Operations.PythonOps.ImportStar(CodeContext context, String fullName, Int32 level)
at Microsoft.Scripting.Interpreter.ActionCallInstruction`3.Run(InterpretedFrame frame)
at IronPython.Runtime.Importer.ImportFrom(CodeContext context, Object from, String name)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`4.Run(InterpretedFrame frame)
at IronPython.Runtime.Importer.ImportTopAbsolute(CodeContext context, String name)
