I am trying to Purge Line Patterns, but I keep getting this error.
File “C:\Users*********\AppData\Roaming\pyRevit\Extensions\EF-Tools.extension\EF_Tools.tab\Maintenance.panel\col1.stack\Purge.pulldown\PurgeLinePatterns.pushbutton\script.py”, line 263, in
NameError: name ‘overrides’ is not defined
IronPython.Runtime.UnboundNameException: name ‘overrides’ is not defined
at IronPython.Runtime.Operations.PythonOps.GetVariable(CodeContext context, String name, Boolean isGlobal, Boolean lightThrow)
at IronPython.Compiler.LookupGlobalInstruction.Run(InterpretedFrame frame)
