Hi I would like to know if anyone has been able to retrieve import instance layers. I am creating a task dialog for the user to input the layer name and then I would check if it exists. Any help is appreciated. Many thanks
# Step 1: Prompt user to select a dwg file
picked = uidoc.Selection.PickObject(ObjectType.Element, "Select DWG file")
dwg_import_instance = doc.GetElement(picked.ElementId)
# Step 2: Prompt user to enter name of AutoCAD layer
result = forms.ask_for_string(prompt="Enter Layer Name:", title="Layer Name")
if result:
layer_name = result
TaskDialog.Show("Result", "The form was cancelled.")
sys.exit()
