I’m trying to create a hook to automaticaly rename and create new worksets after worksharing is enabled.
I got the python script running through RPS without the hook, I got it working as a button, I got the hook working with a simple alert. but I can’t seem to get the python script running with the hook. Is it because the hook is run before the worksets window is opened? Or is it because Revit is still in a transaction?
mind sharing a bit of the code?
might be the way you grab the document. Showing the way you handle transaction for example
also
doc = __eventargs__.Document is what I use in a doc opened hook
and doc = __revit__.ActiveUIDocument.Document in a command hook
might be a clue as well
https://www.revitapidocs.com/2022/51879d12-03fd-0360-d6e1-ce1dcbccbe2d.htm
Documentation says it is allowed to make modifications during this event. Luckily
I’ll share the code when I get into the office
forms.alert("Het model is nu een Central Model")
clr.AddReferenceByPartialName('PresentationCore')
clr.AddReferenceByPartialName("PresentationFramework")
clr.AddReferenceByPartialName('System')
clr.AddReferenceByPartialName('System.Windows.Forms')
clr.AddReferenceByPartialName('RevitAPI')
from Autodesk.Revit import DB
from Autodesk.Revit import UI
# Define list/unwrap list functions
def tolist(input):
result = input if isinstance(input, list) else [input]
return result
def uwlist(input):
return UnwrapElement(result)
# Current doc/app/ui
av = __revit__.ActiveUIDocument.ActiveView
# Collect all worksets
collector = DB.FilteredWorksetCollector(doc)
worksets = collector.OfKind(DB.WorksetKind.UserWorkset).ToWorksets()
# Ensure iterable
if not hasattr(worksets, "__iter__"):
worksets = [worksets]
# Get Workset names
old_names = []
[old_names.append(w.Name) for w in worksets]
rename_names = ["KOW_bouwkundig", "Levels and Shared Grids"]
new_names = ["KOW_constructie", "KOW_situatie"]
# Preparing input from dynamo to revit
wkst_ele = worksets
wkst_nam = rename_names
new_worksets,new_ids,new_bools = [],[],[]
# Do some action in a Transaction
t = DB.Transaction(doc, 'Configure Worksets')
#rename worksets "Workset1" and "Shared Levels and Grids"
wksts,bools = [],[]
for w,n in zip(wkst_ele, wkst_nam):
DB.WorksetTable.RenameWorkset(doc,w.Id,n)
wksts.append(w)
bools.append(w.Name == n)
#create new worksets with the given names
for n in new_names:
w_r = DB.Workset.Create(doc, n)
new_worksets.append(w_r)
new_ids.append(w_r.Id.IntegerValue)
new_bools.append(True)
new_worksets.append(None)
new_ids.append(None)
new_bools.append(False)
tried and adapted the code for french.
It worked as expected as a button as mentionned but not as an hook
the error message makes sense:
File "C:\pyRevit\B1_ToolBar.extension\hooks\doc-worksharing-enabled.py", line 45, in <module>
File "C:\pyRevit\dev\dev\pyrevitlib\pyrevit\revit\db\transaction.py", line 60, in __enter__
Exception: Cannot modify the document for either a read-only external command is being executed, or changes to the document are temporarily disabled.
because when you first enable the worksharing, a series of transaction are enabled in the background in Revit: It creates the worksets, design the file as central and opens up the worksets management windows. While all these operations are running in Revit, you cannot use your own transaction to do stuff.
you might want to try with another hook or stick with a button imho
