Dialog with button for selecting element
We are trying to have a button that once clicked will show a picker to select an element.
The following code works (once). Once clicked again an exception is thrown. Strangely it is printed in a different window (hint?).
This is the resulted of printing the exception:
This name ‘uidoc’ is not defined
Any suggestion on how to fix this would be appreciated?
gdict = globals()
uiapp = __revit__
class MyWindow(Windows.Window):
  def __init__(self):
    xaml_file_path = script.get_bundle_file('dialog/dialog.xaml')
    with open(xaml_file_path, 'r') as f:
      xaml_content = f.read()
    self.dialog = XamlReader.Parse(StringReader(xaml_content).ReadToEnd())
    self.select_button = self.dialog.FindName('selectButton')
    self.select_button.Click += self.handle_select_click
  def show(self):
    self.dialog.ShowDialog()
  def handle_select_click(self, sender, e):
    self.dialog.Dispatcher.Invoke(lambda: self.dialog.Hide())
      choices = uidoc.Selection
      hasPickOne = choices.PickObject(ObjectType.Element)
      if hasPickOne != None:
          print("One element selected.")
      print(e)
    self.dialog.Dispatcher.Invoke(lambda: self.dialog.Show())
MyWindow().show()
For the record, tried a variation of a given example, and again it worked only for first click and then sent a similar exception.
Example that I was not able to re run:
[Select model element from UI upon button click]
The code I used:
from Autodesk.Revit.UI.Selection import ISelectionFilter
gdict = globals()
uiapp = revit
xamlfile = script.get_bundle_file(‘dialog/dialog.xaml’)
def init(self, category_name):
self.category_name = category_name
def AllowElement(self, e):
return True
return True
def init(self):
# self is the instance of the class and we are loading xaml file into that instance
wpf.LoadComponent(self, xamlfile)
def step(self, sender, args):
def parseOptions(self):
def clear(self, sender, args):
def TextBox_KeyDown(self, sender, args):
def handle_command_string(self, sender, args):
def dev(self, sender, args):
self.Hide()
Pipe_Sel = uidoc.Selection.PickObject(ObjectType.Element, CustomISelectionFilter(“Pipes”), “Select a Pipe”)
self.Show()
except Exception:
  print("Operation canceled", "Canceled by the user")
def build(self, sender, args):
MyWindow().ShowDialog()
you mix two different options:
  1. self.dialog.Show()
  2. self.dialog.ShowDialog()
self.dialog.Show() - modeless form. You have to use external event handler and import all the stuff explicitly inside a definition that you run via external event handler.
Or just stick to ShowDialog() :slight_smile:
please see this post Need help with my first xaml file - #6 by hoss53
I just need one working :).
Judging from your emjoi, the second should be easier.
But… The following gives an exception on the second click.
If anyone can find what is wrong, would be great. Otherwise any pointers on how to implement the modeless approach would be great. (If anyone knows how to do it, as a small, paid project, please contact myself: oded@formx.com)
  xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" Title="Formx" Width="400" Height="600" Padding="140,1,4,4">
  <Button Content="Dev" Click="dev"/>
</Window>
gdict = globals()
uiapp = __revit__
xamlfile = script.get_bundle_file('dialog/small_dialog.xaml')
      return True
    return True
  def __init__(self):
      self.Hide()
      uidoc.Selection.PickObject(ObjectType.Element, CustomISelectionFilter(), "Select")
      self.Show()
    except Exception as inst:
      print(inst)
The exception on the second click is: name 'uidoc' is not defined
Have you tried
      self.Hide()
      self.ShowDialog() # <<< Here is the issue :)
      print(inst)
As Tomasz said?
:two_hearts: you guys.
For the future developer, here is a complete working solution:
xamlfile = script.get_bundle_file('dialog.xaml')
      return True
    return True
  def __init__(self):
      self.Hide()
      self.ShowDialog()
      print(inst)
MyWindow().ShowDialog()`Preformatted text`
