Date of creation of a Revit element
Hi everyone, I am tryng to find a way to find the date of creation of an element. Looking in the pyrevit guide, I found a useful basic tool (https://www.notion.so/Get-Revit-Model-Information-673e586c7f7d408898f07114ae4357c1) that allows you to get generic information about an element. Is it possible to include the creation date among these? Thanks in advise for your consideration
I have looked into this before. Revit elements do not have a timestamp property.
Creating a timestamp parameter for elements of interest that is updated when the model opens is one option to give an estimate of when the element was created.
Thank you Steve. Can I ask you if you have an example of a script that is able to do the trick you are describing?
  • through a hook (doc-opened)
    writing data upon doc-opened event in elements of interest only if no data is in that specific parameter, that would do the trick for a basic element creation date tracking _ that would give you a day or so window
    you could use the doc-changed but that might be overwhelming for revit.
  • there are lots of tools around to take snapshots of models (CTC has one, there is one in dynamo as well, …)
  • another approach, maybe my favourite as I believe ones needs to be lazy (or creative, depends on the point of view) is the model comparison tool in B360 to visulaze modified and new elements between published versions
  • a related discussion
from Autodesk.Revit.DB import(
FilteredElementCollector,
BuiltInCategory
from rpw import revit, db
from datetime import date
mech_equipment = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_MechanicalEquipment).WhereElementIsNotElementType().ToElements()
with db.Transaction(doc=doc, name="Update Time Stamp"):
    for m in mech_equipment:
        timestamp = m.LookupParameter('Time Stamp')
        if not timestamp.AsString():
            timestamp.Set(str(date.today()))
Why not add it to the “who did that” button?
That tool only says who created the element, but not include the date.
That is why I suggested to add the functionality
