I don’t know why custom extension can not be recognised when I add the custom Folder path
The only place that works is the Extension folder of pyrevit in C:.… \AppData\Roaming
Usually it is because people point to the ‘name of your extension.extension’ folder instead of the folder containing this folder.
If
"%APPDATA%\pyRevit\Extensions\ribbon.extension\ribbon.tab\......."
Then
"%APPDATA%\pyRevit\Extensions"
Mine
"C:\pyRevit-Master\extensions\ribbon.extension\ribbon.tab\....."
So
"C:\pyRevit-Master\extensions"
