Hi everyone,
I’m making GUI with WPF in combination with Python.
I created a list of checkboxes. Now I want to create Select All and Deselect All buttons. Does anyone know how to do this?
Here’s the Python Code:
import wpf
from System import Windows
import RevitServices
from Autodesk.Revit.DB import*
from collections import OrderedDict
from pyrevit import UI
xamlfile = script.get_bundle_file('ui.xaml')
# Definitions
def SortedDictionary(keys, values):
dictTemp = dict(zip(keys, values))
keysSorted = sorted(keys)
dictSorted = OrderedDict()
for key in keysSorted:
dictSorted[key] = dictTemp[key]
return dictSorted
sheets = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Sheets).WhereElementIsNotElementType().ToElements()
sheetNumbers = []
[sheetNumbers.append(sheet.get_Parameter(BuiltInParameter.SHEET_NUMBER).AsString()) for sheet in sheets]
sheetNames = []
[sheetNames.append(sheet.get_Parameter(BuiltInParameter.SHEET_NAME).AsString()) for sheet in sheets]
sheetsDict = SortedDictionary(sheetNumbers, sheets)
sheetNumbers.sort()
sheetNames.sort()
class CheckBoxListItem:
def __init__(self, number, name, isChecked=False):
self.Number = number
self.Name = name
self.IsChecked = isChecked
listViewData = []
for number, name in zip(sheetNumbers, sheetNames):
item = CheckBoxListItem(number, name)
listViewData.append(item)
class MyWindow(forms.WPFWindow):
def __init__(self):
forms.WPFWindow.__init__(self, xamlfile)
self.ListBox1.ItemsSource = listViewData
def SelectAll_Click(self, sender, e):
#some code to select all
return "wip"
def DeselectAll_Click(self, sender, e):
#some code to deselect all
return "wip"
@property
def selected_sheets(self):
selected_items = [item for item in self.ListBox1.Items if item.IsChecked]
selected_numbers = [item.Number for item in selected_items]
return [sheetsDict[name] for name in selected_numbers]
@property
def zoek_naar(self):
return self.TextBox1.Text
@property
def vervang_door(self):
return self.TextBox2.Text
def button_click(self, sender, args):
t = Transaction(doc, "change sheet nrs")
for sheet in my_window.selected_sheets:
sheet.get_Parameter(BuiltInParameter.SHEET_NUMBER).Set(sheet.SheetNumber.Replace(my_window.zoek_naar, my_window.vervang_door))
def button_click_close(self, sender, args):
self.Close()
# Show dialogue
my_window = MyWindow()
my_window.ShowDialog()
And my WPF-code (XAML):
<Window xmlns = "http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x = "http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:av="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" mc:Ignorable="av"
Title="Verander Sheet Number"
MinWidth="550" Width="550" ResizeMode="NoResize" SizeToContent="Height" WindowStartupLocation="CenterScreen" >
<Window.Resources>
<DataTemplate x:Key="CheckBoxTemplate">
<StackPanel Orientation="Horizontal">
<CheckBox IsChecked="{Binding IsChecked}" />
<TextBlock Text="{Binding Number}" Margin="10,0,0,0" FontWeight="Bold" />
<TextBlock Text=" - " />
<TextBlock Text="{Binding Name}" />
</StackPanel>
</DataTemplate>
</Window.Resources>
<StackPanel Margin="10">
<Label FontWeight ="Bold" Content="Selecteer Sheets"/>
<Border BorderBrush="Black" BorderThickness="0.5">
<ScrollViewer Height="200" Margin="5">
<ItemsControl x:Name="ListBox1" ItemTemplate="{StaticResource CheckBoxTemplate}"/>
</ScrollViewer>
</Border>
<StackPanel Orientation="Horizontal" Margin="0,5,0,0">
<ToggleButton x:Name="SelectAllButton" Content="Select All" Click="SelectAll_Click" Width="100" Margin="0,0,10,0"/>
<Button Content="Deselect All" Click="DeselectAll_Click" Width="100"/>
</StackPanel>
<Grid Margin="0,5,0,0">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="120" />
<ColumnDefinition Width="1*" />
</Grid.ColumnDefinitions>
<Grid.RowDefinitions>
<RowDefinition Height="1*"/>
</Grid.RowDefinitions>
<Label FontWeight ="Bold" Content="Zoek naar" Grid.Column="0" Grid.Row="0"/>
<TextBox Name="TextBox1" Text="ref" Margin="3" Width="150" MinWidth="150" Grid.Column="1" Grid.Row="0" HorizontalAlignment="Left"/>
<Label FontWeight ="Bold" Content="Vervang door" Grid.Column="0" Grid.Row="1"/>
<TextBox Name="TextBox2" Text="woning" Margin="3" Width="150" MinWidth="150" Grid.Column="1" Grid.Row="1" HorizontalAlignment="Left"/>
</Grid>
<Grid>
<ColumnDefinition Width="3*" />
<Button Content="Verander Sheet Numbers" Click="button_click" Margin="0,5,5,0"/>
<Button Content="Close" Click="button_click_close" Margin="0,5,5,0" Grid.Column="1"/>
</Grid>
</StackPanel>
</Window>
There’s a lot of information on C# on the internet, but I have 0 experience with that ![]()
Any help is welcome!
PS: If you see any weird or unlogical things in my code, feel free to let me know aswell.
