Hi there,
Im trying to create a new wall type in Revit. I first clone an existing wall type and than i am modifying the layers (e.g. thickness) of the layers. But somehow Im not able to change the actual
thickness. It will create a new wall type though, but its just the same as the base object.
thanks a lot! Matthias
wall_types = list(FilteredElementCollector(doc).OfClass(WallType).ToElements())
base_type = next((wt for wt in wall_types if wt.Name == base_type_name), None)
# --- Start Transaction ---
t = Transaction(doc, f"Create Wall Type: {new_type_name}")
# Delete existing wall type with same name
existing = next((wt for wt in wall_types if wt.Name == new_type_name), None)
if existing:
doc.Delete(existing.Id)
output.print_md(f"Deleted existing wall type: `{new_type_name}`")
# Duplicate the base wall type
new_type = base_type.Duplicate(new_type_name)
if not new_type:
raise Exception("WallType.Duplicate() returned None")
# Get compound structure (cannot create from scratch)
cs = new_type.GetCompoundStructure()
if cs is None:
raise Exception("Base wall type has no compound structure.")
# Modify structure layer
thickness_ft = meters_to_feet(core_thickness_mm / 1000.0)
layers = list(cs.GetLayers())
# Modify structure layer directly
modified = False
print("layers: ", len(layers))
for i, layer in enumerate(layers):
# if layer.Function == MaterialFunctionAssignment.Structure:
layer.Width = core_thickness_mm
output.print_md(f"Modified layer {i} to {thickness_ft} ft")
layers[i] = layer
output.print_md(f"Updated layer {i} to {layer.Width} ft")
modified = True
output.print_md(
f"Modified structure layer at index {i} to {core_thickness_mm} mm"
if not modified:
raise Exception("No structure layer found in base wall type.")
cs.SetLayers(layers)
output.print_md(f"Created new wall type: `{new_type_name}`")
return new_type
