Hello!
I am working on a way to create a dimension in plan (and elevations and other flat views) between two points/planes.
I tried creating and getting a working reference from Reference Planes and Points. Reference planes get error that they are not geometry, hence I cannot create dimensions to them. Newly created points return None reference from Point.Reference method.
My goal is to have a method that I can give as an argument: two points and dimension-line offset-vector (or something simple of this sort). Do you know of a method to create a revit dimension between two programatically created objects?
If this fails Im considering making a mockup dimension from lines and textnotes which would give me bigger control and simplicity.
