Create views from new levels (Floor Plan, Structural Plan, CeilingPlan)
This script automatically creates plan views from selected levels in Revit. The user can choose the view type (floor, ceiling, structural), discipline, and customize naming with prefixes/suffixes. It also supports assigning an optional ‘SubSpecialty’ parameter and ensures multilingual compatibility for view types.
__title__     = "ViewFromLevels"
__author__    = "Oscar Mendoza"
__doc__ = """Version = 1.5
Date    = 22.10.2025
Description:
Create plan views automatically based on selected levels.
User can define:
- View type (Floor, Ceiling, Structural)
- Discipline (Architecture, MEP, etc.)
- Prefix and Suffix for naming
- Sub-specialty parameter (optional)
How-to:
-> Run the script
-> Select one or multiple Levels
-> Choose View Type and Discipline
-> Define Prefix/Suffix and SubSpecialty
-> The script will create the views automatically
Last update:
- [21.10.2025] - 1.0 Initial release
- [22.10.2025] - 1.1 Added Discipline, Prefix/Suffix and SubSpecialty options
- [25.11.2025] - 1.5 Fixed Multi-Language support for View Type
Author: Oscar Mendoza"""  # Description
### EXTRA: You can delete this
__helpurl__ = 'https://www.youtube.com/watch?v=dQw4w9WgXcQ'
__min_revit_ver__ = 2021
__max_revit_ver__ = 2026
# ⬇️ IMPORTS
import clr, sys
clr.AddReference("System")
from rpw.ui.forms import *
#📦VARIABLES
uidoc = __revit__.ActiveUIDocument   #type: Document
selection = uidoc.Selection         #type: Selection
# 💻MAIN
def vista_create(nivel, nombre=None, config = None):
    Creates a plan view.
    config may contain: type, discipline, SubSpecialty
    ## CONFIG ##
    if config is None:
        config = {}
    tipo = config.get("type", "Floor Plan")
    disciplina = config.get("discipline", "Plumbing")
    SubEspecialidad = config.get("SubEspecialidad", None)
    ## code ##
    existing_views = [v for v in FilteredElementCollector(doc).OfClass(View).ToElements() if v.Name == nombre]
    if existing_views:
        print("The view '{}' already exists. Skipped.".format(nombre))
        return None
    idTipo = dic_ViewTypes[tipo]
    with Transaction(doc, "Create New View") as t:
        # Name
        vista = ViewPlan.Create(doc, idTipo.Id, nivel.Id)
        vista.Name = nombre
        # View Discipline
        bic = BuiltInParameter.VIEW_DISCIPLINE
        vista.get_Parameter(bic).Set(int(dic_disc[disciplina]))
        # Assign SubSpecialty if applicable
        if SubEspecialidad:
            param = vista.LookupParameter("SubEspecialidad")
            if not param:
                mensaje2 = "The parameter does not exist"
                forms.alert(mensaje2, title="OMTools | View Generator", exitscript=True)
            if param:
                param.Set(SubEspecialidad)
        return vista
#Filter Views
View_Types = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
View_Type_Plan = [vt for vt in View_Types if vt.ViewFamily == ViewFamily.FloorPlan][0]
View_Type_Ceiling = [vt for vt in View_Types if vt.ViewFamily == ViewFamily.CeilingPlan][0]
View_Type_StructuralPlan = [vt for vt in View_Types if vt.ViewFamily == ViewFamily.StructuralPlan][0]
## DICTS ###
dic_ViewTypes = {"Floor Plan": View_Type_Plan, "Ceiling Plan": View_Type_Ceiling, "Structural Plan": View_Type_StructuralPlan}
dic_disc = {"Electrical": ViewDiscipline.Electrical, "Structural":ViewDiscipline.Structural, "Coordination":ViewDiscipline.Coordination,
           "Architectural": ViewDiscipline.Architectural, "Mechanical": ViewDiscipline.Mechanical, "Plumbing":ViewDiscipline.Plumbing }
### COLLECTS ###
niveles = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Levels).WhereElementIsNotElementType().ToElements()
niv_dic = {x.Name:x for x in niveles}
### UI 1 ######
niveles_ui =forms.SelectFromList.show(sorted(niv_dic.keys()),title="OMTools | View Generator", multiselect=True, button_name = "Select item")
if not niveles_ui or niveles_ui is None:
    mensaje = "No levels were selected"
    forms.alert(mensaje, title="OMTools | View Generator", exitscript=True)
niveles_list = [niv_dic[x] for x in niveles_ui]
### UI 2 ######
components = [Label("Select Type of View"), ComboBox('ViewType', list(dic_ViewTypes.keys())) ,
              Label("Select Discipline"), ComboBox('Discipline', list(dic_disc.keys())),
              Label("Prefix"), TextBox('Prefix', Text="") ,
              Label("Suffix"), TextBox('Suffix', Text=""),
              Label("SubSpecialty (Optional Parameter)"), TextBox('SubEspecialidad', Text=""),Separator(),
              Button("Select")]
form = FlexForm("OMTools | View Generator", components)
form.show()
## RESULT ##
ViewType = str(form.values["ViewType"])
discipline = form.values["Discipline"]
Prefix = form.values["Prefix"]
Suffix = form.values["Suffix"]
SubEspecialidad = form.values["SubEspecialidad"]
views_created = 0
for lvl in niveles_list:
    nombre_vista = Prefix + lvl.Name + Suffix
    vista = vista_create(lvl, nombre_vista, config={"type":ViewType, "discipline":discipline, "SubEspecialidad":SubEspecialidad})
    if vista:
        views_created += 1
# Final result
Alert(
    "✅ {} views were created successfully.".format(views_created),
    header="Process completed",
    exit=False)
