Create Grid from Auto cad
from pyrevit import revit, DB
from Autodesk.Revit.DB import ImportInstance, Options, Line
# Get the active document and user interface document
uidoc = revit.uidoc
# Get the active view (where detail lines will be created)
active_view = doc.ActiveView
# Get all ImportInstance elements (CAD links) in the project
CAD_links = DB.FilteredElementCollector(doc).OfClass(ImportInstance).ToElements()
# Initialize an empty set to store layer names
layer_names = set()
# Initialize a counter for bound curves
bound_curve_count = 0
# Start a transaction to modify the Revit document
t = DB.Transaction(doc, "Create Detail Lines from CAD Curves")
# Iterate through all the CAD links
for link in CAD_links:
    link_cat = link.Category
    link_sub_cats = link_cat.SubCategories
    # Iterate through all the subcategories
    for sub_cat in link_sub_cats:
        options = Options()
        options.IncludeNonVisibleObjects = False  # Exclude non-visible objects if needed
        # Check if the subcategory name matches "Grid" (adjust as needed)
        if "Grid" in sub_cat.Name:
            # Get the geometry of the subcategory
            geometry = link.get_Geometry(options)
            # Add the subcategory name to the set
            layer_names.add(sub_cat.Name)
            # Iterate through the geometry objects
            if geometry is not None:
                for geom_obj in geometry:
                    # If geometry is a GeometryInstance (symbol)
                    if isinstance(geom_obj, DB.GeometryInstance):
                        instance_geometry = geom_obj.GetSymbolGeometry()
                        for inst_geom_obj in instance_geometry:
                            if isinstance(inst_geom_obj, DB.Curve):
                                # Skip unbound curves
                                if inst_geom_obj.IsBound:
                                    # Create a Revit detail line from the curve in the active view
                                    detail_line = doc.Create.NewDetailCurve(active_view, inst_geom_obj)
                                    bound_curve_count += 1
                    # If geometry is a Curve (line)
                    elif isinstance(geom_obj, DB.Curve):
                        if geom_obj.IsBound:
                            detail_line = doc.Create.NewDetailCurve(active_view, geom_obj)
# Commit the transaction
# Output the unique layer names
print("Layer Names: {}".format(layer_names))
# Output the total count of bound curves
print("Total number of bound curves: {}".format(bound_curve_count))
apply this script to create grid from cad link , but not create grid line.
any one have idea…
@shuvro.arc ,
i can just share a dynamo issue that i solved partly with python. You can migrate some ideas to clean python…
