Create Detail Lines from CAD link
I’m trying to create detail lines based off geometry in a CAD link. I would like it to basically work like pick line tool.
One issue I’m running into is getting different type of geometry and trying to pull useable data out of them to us with the doc.Create.NewDetailCurve method. Is there a simpler way to do this than having different workflows for arc, polylines, and lines?
I’m starting with the PolyLine class, but can’t seem to get curves from it, only coordinates and I don’t think that is enough to make accurate lines.
For arcs it looks like I could get radius, center getendpoints which would probably be enough.
@Crapai ,
i try also to solve this… i come until here with dynamo. I still do not know how Geometry works in PyRevit.
__title__   = "CADLinesToDetaillines"
__author__  = "AD"
__version__ = "Version: 1.1"
__doc__ = """Version = 1.0
Date    = 31.10.2023
Description:
Check wether any door does have a tag.
How-to:
-> Click on the button
-> Create Detaillines based on CADLayers
-> check the result
Last update:
- [11.02.2022] - 1.1 added Revit 2022 Support.
- [21.12.2021] - 1.0 RELEASE
To-Do:
- Move functions to lib
_____________________________________________________________________"""
# ╩╩ ╩╩  ╚═╝╩╚═ ╩ ╚═╝ IMPORTS
import os, sys, datetime
import time
import traceback
# pyRevit
from pyrevit import forms, revit, script
# .NET Imports
clr.AddReference('System')
# List_example = List[ElementId]()
import System
#  ╚╝ ╩ ╩╩╚═╩╩ ╩╚═╝╩═╝╚═╝╚═╝ VARIABLES
time_start = time.time()
def purge_points(coords_xyz):
    out_pts = []
    for c_xyz in coords_xyz:
        if all(p.DistanceTo(c_xyz) > 0.001 for p in out_pts):
            out_pts.append(c_xyz)
    return out_pts
def get_Curves_from_CAD(importinstance, lst_layerName=[]):
    datas = []  # 💥 Initialize an empty list to store data
    # 🔹 Create an Options object for importing geometry
    opt = Options()
    # 🎈 Get the geometry of the import instance
    geoSet = importinstance.get_Geometry(opt)
    # Iterate through the geometry set
    for geo in geoSet:
        if isinstance(geo, GeometryInstance):
            for g in geo.GetInstanceGeometry():
                if isinstance(g, DB.PolyLine):
                    # 📍 Get the graphics style and name of the current polyline
                    gStyle = doc.GetElement(g.GraphicsStyleId)
                    gstyleName = gStyle.GraphicsStyleCategory.Name
                    # ❗ Check if the layer name is in the specified list
                    if gstyleName in lst_layerName:
                        purge_coordinates = purge_points(g.GetCoordinates())
                        # ▶ Create a DesignScript polycurve from the polyline
                        ds_polycurve = DS.PolyCurve.ByPoints([p.ToPoint() for p in purge_coordinates], False)
                        datas.append(ds_polycurve)
    return datas
# 1️⃣ import instance and layer name list from the Revit input
importInstance = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks).WhereElementIsNotElementType().ToElements()
lst_layerName = "101_Demo"
# 2️⃣ Call the function and assign the result to the output variable
OUT = get_Curves_from_CAD(importInstance, lst_layerName)
print(OUT)
time_end = time.time()
print("\n The code took {} seconds to run.".format(duration))
# ✅ End
This is how it works for me
def create_detail_lines_from_geometry(geometry_elements):
    """Create detail lines from the geometry of an import instance.
    args:
        geometry_elements: The geometry elements of the import instance.
    return: The created detail lines."""
    ids = []
    for g in geometry_elements:
            if "PolyLine" in str(g):
                polyline = DB.PolyLine.Clone(g)
                # get coordinates of the polyline
                points = polyline.GetCoordinates()
                # create detail lines for each segment
                for i in range(len(points) - 1):
                    line = DB.Line.CreateBound(points[i], points[i + 1])
                    x = doc.Create.NewDetailCurve(doc.ActiveView, line)
            elif "Arc" in str(g):
                x = doc.Create.NewDetailCurve(doc.ActiveView, DB.Arc.Clone(g))
            elif "Ellipse" in str(g):
                x = doc.Create.NewDetailCurve(doc.ActiveView, DB.Ellipse.Clone(g))
            elif "Line" in str(g) and "PolyLine" not in str(g):
                style_id = g.GraphicsStyleId
                style_cat = doc.GetElement(style_id).GraphicsStyleCategory
                if "DIM" in str(style_cat.Name):
                    x = doc.Create.NewDetailCurve(doc.ActiveView, DB.Line.Clone(g))
            elif "Curve" in str(g):
                x = doc.Create.NewDetailCurve(doc.ActiveView, DB.Curve.Clone(g))
            elif "Solid" in str(g):
                create_filled_region(g)
                print("Unknown geometry type:", str(g))
           ids.append(x.Id)
    return x
