Copying filters from one Revit document to another
Hello everyone!!!
I am trying to create a tool with pyrevit that copies the filters from one project to another, but I run into this error and I can not figure it out. Maybe you could find the mistake and you can point it out.
This is the error:
This is the script:
import pyrevit
from pyrevit import revit,DB
from pyrevit import forms,script
doc_from = forms.select_open_docs(title='Select a document',
                                    button_name='Select',
                                    width= 500,
                                    multiple=False)
if not doc_from:
    forms.alert("No Revit document selected", exitscript=True)
elif doc_from.IsFamilyDocument:
    forms.alert("Must choose a non-family document", exitscript=True)
# Get all filters from the document
all_views = DB.FilteredElementCollector(doc_from).OfCategory(DB.BuiltInCategory.OST_Views).WhereElementIsNotElementType().ToElements()
views_with_filter = [v for v in all_views if v.GetFilters()]
filter_ids = [v.GetFilters() for v in views_with_filter]
filters = [doc_from.GetElement(f_id) for f_id in filter_ids]
print(filters)
selected_filters = forms.SelectFromList.show(filters,
                                            title='Select the destination view/viewtemplates',
                                            multiselect=True,
                                            button_name='Select source View/ViewTemplate')
if not selected_filters:
    script.exit()
Try this:
Greets
Hey @Manuel486
I have tried that tutorial and it works perfectly when I have to copy the filters from one view/view template to another, but know I want to copy the filters from one opened project to another.
Then you have to use this tool first.
That may work. I was wondering if there could work by copying only the filters with it overrides
I think your line 30 refers to this line
I think filter_ids is a list of lists (more accurately a list with a list of ids for each view’s filters), not a list of ids like you’re expecting with this code.
I have managed to solve the error. :slightly_smiling_face:
Now after I copy the filter to another project and try to apply to a selected view, this error comes out
The code is this:
import pyrevit
                                    width= 500,
                                    multiple=False)
if not doc_from:
# Get all views from the document
# Get all views with filter
dict_views_with_filters = {i.Name:i for i in views_with_filter}
selected_src_view = forms.SelectFromList.show(sorted(dict_views_with_filters),
                                            title='Select the source view/viewtemplates',
                                            multiselect=False,
# Select the filters from the source view
src_view = dict_views_with_filters[selected_src_view]
filters = sorted([doc_from.GetElement(f_id) for f_id in src_view.GetFilters()])
                                            title='Select source filters',
                                            multiselect=True,
                                            button_name='Select filter',
											name_attr = "Name")
	script.exit()
# Select the destination views
dest_views = DB.FilteredElementCollector(doc).OfCategory(DB.BuiltInCategory.OST_Views).WhereElementIsNotElementType().ToElements()
dict_dest_views = {v.Name:v for v in dest_views}
selected_dest_view = forms.SelectFromList.show(sorted(dict_dest_views),
                                            multiselect=True,
                                            button_name='Select destination View/ViewTemplate')
selected_dest_views = [dict_dest_views[v] for v in selected_dest_view]
# Copy the filters to another project
transform = DB.Transform.Identity
opts = DB.CopyPasteOptions()
ids = [e.Id for e in selected_filters]
ids_copy = List[DB.ElementId](ids)
print(ids_copy)
with revit.Transaction('Copy filters'):
	DB.ElementTransformUtils.CopyElements(doc_from,ids_copy,doc,transform,opts)
for view_filter in selected_filters:
	filter_overrides = src_view.GetFilterOverrides(view_filter.Id)
	for view in selected_dest_views:
		view.SetFilterOverrides(view_filter.Id, filter_overrides)
I found the solution. :blush: :blush:
The exception was raised because the copied filter had another elementId, so when it had to apply the graphics from the filter from the source project, it could find the same filter in the destination project.
