Copy tool from pyRevit running slow
Hi all,
When I test the tool in pyRevit, for example, Sheets → Select Sheets. Running in the pyRevit tab takes <1 second.
But if I create a custom extension, and copy the button Select Sheets, it takes 3-4 seconds to run.
More detail: Select sheets source code is using the pyrevit lib.
"""Select multiple sheets from a list"""
#pylint: disable=import-error,invalid-name
from pyrevit import revit
sel_sheets = forms.select_sheets(title='Select Sheets')
if sel_sheets:
    selection.set_to(sel_sheets)
Could you please explain why pyrevit lib works so fast in pyRevit tab but the others tab is slow?
Thank you
Tien
It might be a Cache thing.
If you run the function again, I am pretty sure it runs faster/at normal speed
Hi Jean,
Thanks for your reply.
But I ran many times and had the same issue. :frowning:
You can check the video attached to see the behavior
https://drive.google.com/file/d/1dL0oSiafjglPN8Rpu-d8U5-VIY53E5D1/view?usp=sharing
just found some interesting problem
I’m watching the Task Manager while running the pyRevit tool and the tool in the custom extension.
pyRevit tool only costs about 3 MB to run, but the tool in the custom extension costs about 30 MB.
And the memory is never released after finishing the tool.
As you can see I opened the same project, and the memory is bigger after running time (just click on the tool and hit Esc). the more click on the tools, the more memory cost.
