Command-exec hook
Is it possible to use an if statement to set whether a command is replaced or not by a command-exec hook?
i.e.
if doc is a family document:
post default command
print message and don’t post command
sure, this is an example on the doc-opened hook:
    from pyrevit import HOST_APP, framework
    from pyrevit import DB, revit
    # from pyrevit import script
    # from os import path
    doc = __eventargs__.Document
    if not doc.IsFamilyDocument:
        do something
Thanks but unfortunately that results in the same issue (looping of the replaced command being posted by itself) which I think is because command-exec hooks replace the PostableCommand at all references so the default command can’t be posted.
This is a hook which disables Import CAD in .rvt files. Import CAD is necessary in some rare cases (mostly .rfa files) and I can’t get that bit to work.
If you want to try it this is the code from a command-exec[ID_FILE_IMPORT] hook:
from pyrevit import script, revit
from Autodesk.Revit.UI import UIApplication, RevitCommandId, PostableCommand
uiapp = UIApplication(doc.Application)
count = []
    output = script.get_output()
    output.resize(100, 300)
    output.set_title('Forbidden')
    output.print_md('NEVER import CAD to Revit projects. Use Link CAD.')
    found_id = RevitCommandId.LookupPostableCommandId(PostableCommand.ImportCAD)
    uiapp.PostCommand(found_id)
I did not try it quite yet,
but you could try mine for inplace components:
This one works fine, you will get the structure from there:
    # -*- coding: UTF-8 -*-\n"
    res = forms.alert("ATTENTION!\n\n"
                      "Les familles insitu sont globalement une mauvaise pratique, "
                      "contrairement aux familles chargeables, elles ont des inconvénients: \n"
                      " - Problèmes d'affichage,\n"
                      " - Pas possible d'identifier son niveau adéquatement,\n"
                      " - La copie va créer un double de l'original,\n"
                      " - Impossible de modéliser de manière paramétrique\n\n"
                      "Voulez-vous vraiment créer une famille in situ?",
                      options=["Valider",
                               "Annuler",
                               "Plus d'information sur les familles in situ"],
                      title="Familles In Situ",
                      footer="BIMONE Hooks")
    if res  == "Valider":
       EXEC_PARAMS.event_args.Cancel = False
       # logging to server
       from hooksScripts import hooksLogger
       hooksLogger("Inplace Component", doc)
    elif res  == "Annuler":
       EXEC_PARAMS.event_args.Cancel = True
    elif res  == "Plus d'information sur les familles in situ":
       url = 'https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Model/files/GUID-B63B71A6-E8F2-40C9-9CAC-FFB738C431E4-htm.html'
       script.open_url(url)
Clever solution, but having tried both a copy/paste and modified version it’s still not working for me!
results in
Exception: Event cannot be cancelled!
Do you know what might be stopping it?
No idea.
and I cannot try right now.
you could take a look @ https://github.com/eirannejad/pyRevit/blob/develop/extensions/pyRevitDevHooks.extension/hooks/command-exec[ID_INPLACE_COMPONENT].py
and all the hooks there
https://github.com/eirannejad/pyRevit/tree/develop/extensions/pyRevitDevHooks.extension/hooks
I was using command-exec incorrectly… Using command-before-exec worked perfectly as it allows you set rules to the default command, whereas command-exec replaces the default command with another. Thanks for your help, again
Hi Jean-Marc, sorry about to replying here, it is just that I am trying this solution and it seems to be working well but giving me this error, using Revit 2022.1 and pyRevit v4.8.13.
this is the code I am using:
res = forms.alert("WARNING!\n\n"
                    "In-situ families are generally a bad practice,"
                    "unlike loadable families, they have drawbacks:\n"
                    " - Display issues,\n"
                    " - Couldn't identify its level properly,\n"
                    " - The copy will create a duplicate of the original,\n"
                    " - Unable to model parametrically\n\n"
                    "Do you really want to create a family in situ?",
                    options=["Validate",
                            "Cancel",
                            "More information about families in situ"],
                    title="Families In Situ",
                    footer="HDS Hooks")
if res  == "Validate":
    # logging to server
elif res  == "Cancel":
elif res  == "More information about families in situ":
    url = 'https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-B63B71A6-E8F2-40C9-9CAC-FFB738C431E4'
Any idea of why it do not recognizes the hooksScripts module?, I have tried with the hooks_logger too and gives me the same error.
Thanks in advance!.
