Hello everyone, Has anyone experience the issue where the UI for the color splash bottom is not scale properly and I cannot see the whole content of the UI? I am attaching the image. and what is the work around to remove a Color scheme already created?
Do you mean this zoom? if so, I reopened the Revit session with a 100% zoom and I run the same script and yes it works fine, only the size is really small. Than you very much @Jean-Marc.
How about to remove the color splash from a view, is this possible>
As far as I know I am using the lastest version, or at least that what I thought. Anyways, just to be clear if I apply a color replacement there is no way to clear that?
