Clone does not include bin folder
In the past, I’ve succesfully installed pyRevit with CLI. However, I run into problems with both the newest version 6.4 and the older 5.3. This is the command I’m using: pyrevit clone main core --dest=“C:\pyRevit\main”
It does create the folders ‘pyrevitlib’ and ‘site-packages’, but not ‘bin’. Therefore it also fails to load in Revit. Copying the clone from an older PC where it works fine also does not result in a working pyRevit.
You need to download the latest wip CLI.
This should solve your issue
Binaries have been removed from the repo and the new cli now download the latest built binaries from the artifacts
